Is my car TPI or TBI
Old Oct 25, 2008 | 04:11 PM
88beast's Avatar
I have a 1988 camaro 5.0L 305 fuel injected not carburator. Is it TPI or TBI? Because I am trying to get a SLP air intake kit, but it says only for TPI and not TBI.
Old Oct 25, 2008 | 04:45 PM
FUNIROC's Avatar
Car: 1989 IROC
Re: Is my car TPI or TBI
In your VIN# if you have a F as the 8th digit then you should have a TPI. As long as the car still has the original engine.
Old Oct 25, 2008 | 05:02 PM
kcb37's Avatar
If you have a carb air cleaner you have a TBI. A TBI will resemble a carb, but has 2 injectors directly over top of the throttle bores.
If you have an intake that looks like an LT1 then you have a TPI.
Old Oct 25, 2008 | 05:45 PM
88beast's Avatar
thank you so I figured out that i have a TBI, I have one more question though. What is my engine called whats the code?
Old Oct 25, 2008 | 06:00 PM
FUNIROC's Avatar
Car: 1989 IROC
Here is a picture of what the TPI engine should look like.
Attachment 165870
Old Oct 25, 2008 | 06:08 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
E code in the VIN
Old Oct 25, 2008 | 09:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
TBI, VIN code E, is called "LO3".
TPI, VIN code F, is called "LB9".
Old Oct 25, 2008 | 11:47 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Also VIN 8 is TPI (L98 - 350)
Old Oct 25, 2008 | 11:53 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
you have to watch the vin code E & F mine has them both in it but mine is a TBI engine
this is tbi
Old Oct 26, 2008 | 02:06 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
You can only have one 8th digit.It`s either or.No way to have both unless you`re refering to the F that is the fourth digit denoting body type,as in F body.That is an extremly clean engine bay you have.Very nice
Old Oct 26, 2008 | 02:28 AM
five7kid's Avatar
But the original poster said it was a 305. . .
Old Oct 26, 2008 | 07:51 AM
kcb37's Avatar
You should have an Lo3.
Unless it has been changed.
Old Oct 26, 2008 | 08:43 AM
Daves03's Avatar
Engine: 305 V8 TBI
im just saying you cant go after the vin blindly if you dont know what to look for because sometimes they can be tricky.
Old Oct 26, 2008 | 08:30 PM
five7kid's Avatar
It's not too tricky if you can count to 8.
MustangBeater20
Oct 29, 2022 09:20 PM
Wade787b
Sep 29, 2015 01:15 PM
