Cam Question?
Old Oct 31, 2008 | 06:24 PM
rockabillyruss's Avatar
Car: '86 Firebird/ '07 V-Star Midnight
Engine: V8 transplanted by po/1100cc v-twin
Axle/Gears: i'll be looking
Cam Question?
I'm pretty new to sbc performance, and the f-body in general. I would like to know if anyone can offer me a definitive answer to this question. If I install this cam will I have any valve to piston clearance issues on a 305 built before 1986 with stock bottom end and heads? as a side note, if all is well in that area, should I look at changing the valve springs? My plan is to install this combo package on the 305 in my Firebird. In addition to the things in that kit, I am already planning on putting new pushrods in and replacing all of the bolts i will be taking out to install all of this. Thanks in advance for any advice.
Rusty
Old Oct 31, 2008 | 06:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cam Question?
Not likely.
Wouldn't be a bad idea.
Old Oct 31, 2008 | 06:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Cam Question?
you should have no problems with that cam, its almost identical to the factory L98 roller cam in lift and specs and that works great in 305's and i dont think the pistons changed from 86 to the 87up roller years. your still probly .025 in the hole and should have plenty of space with that setup.
My pistons are as close to the head as factory from my calcs and i got plenty of clearance with a 230/245 .600+ lift cam
Yes replace the valve springs but with any recommended flat tappet cam spring that will fit in stock pockets and most will Comp 981's i think are standard flat tappet springs that work well,even for mild roller cams so you should be good there.
replace pushrods too while your at it. Always a good choice.
That package should work well, i dont know a whole lot on carbs but for a 305 i know you dont want or need to go too large. you could actually jump up a cam size if you wanted
Old Nov 1, 2008 | 09:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam Question?
Your combo is very similar to a 305 I did years ago. Seems okay to me.
Old Nov 1, 2008 | 10:00 PM
Re: Cam Question?
Thanks to everyone who replyed. One more question, would it be ok to run my existing valve springs a couple months until i get a lil more money?
I'm not familiar with the L98, what is it?
Last edited by rockabillyruss; Nov 1, 2008 at 10:02 PM. Reason: Automerged Doublepost
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
