POST YOUR VORTEC SET UP!
Old Nov 11, 2008 | 10:07 AM
10secondhopeful's Avatar
Car: '84 Z28
Lets see what you guys did with vortec heads, include cam shaft, rocker arms, type of springs (stock, beehive, etc), just everything pretty much...
HP and torque ratings! Quarter mile times!
Old Nov 12, 2008 | 10:26 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: POST YOUR VORTEC SET UP!
.010 over L31 long block
xr 282 hr comp roller cam
10.24:1 comp.
6.0 rods
mild porting on the heads
comp springs
Stock rockers were slotted for the higher lift cam (no dyno info since rollers were added)
summit intake (port matched)
750 cfm holley 3310
stock bbc oil pump
holley blue fuel pump
accel billet dizzy
426hp 432 lbs at the flywheel
Once I get the bugs worked out, I should get low 12's or high 11's. Right now it's 12.84 @ 109.3
Old Nov 12, 2008 | 10:59 AM
Car: '84 Z28
sweet man nice set up
Old Nov 12, 2008 | 10:20 PM
skyhigh4by's Avatar
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
Mine isnt anything special but
stock 350 4 bolt main
Vortec heads from 97 truck
Hooker LT's
Comp cams 268 complete kit
Performer intake
SMI stage II QJet
Not a major build but I think Once I hit the road I should be a bit happier than the 305.
Old Nov 13, 2008 | 08:31 AM
skinny z's Avatar
Vortec heads w/ three angle vavle job, elongated push rod holes and screw in studs w/ guide plates,
Comp Pro Magnum 1.6 rockers,
Comp Pro Magnum push rods,
1979 350 4-bolt "010" block, std. bore,
Speed Pro Hypereutectic coated pistons w. moly ring pack,
Stock rods resized w/ ARP bolts,
Stock cast crank, polished,
Fluidampr balancer,
SFI flexplate,
Clevite bearings,
Stock oil pump w/ Z-28 spring,
Victor Reinz .026" head gasket,
Rpm Air Gap intake,
Holley 670 Street Avenger,
Comp XR276HR cam,
Mallory distributor w/ 18* total mechanical advance ( 16* initial )
MSD 6AL ignition,
Flamethrower coil,
Hedman LT headers, 1 5/8" w/ 2 1/2" by xxx collectors,
Still dialing in the combination with 700R4, TCI Street Fighter convertor, 3.70 gear and 26" drag radials. Best so far of 12.9 @ 107 w/ 1.79 60' ( Broke pinion gear on that one )
Race weight 3650lbs w/ driver and a full tank of 94 Octane,
22 mpg on the highway.
Old Nov 13, 2008 | 09:26 AM
Car: '84 Z28
nice ride, keep them coming guys!
Old Nov 13, 2008 | 02:15 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
406 ci
+.030 2 bolt 400sbc 0 decked
cast GM 400 crank
GM 062 Vortec heads: ported with 2.02x 1.60 manley valves
KB 168+.030 pistons
GM 5.7 rods
9.8:1 cr
CrossWind dual plane intake Holley/Proform custom build 750 HP carb
Carter P4594 electric fuel pump GM "L-88" air cleaner
Comp XE284H-10 hyd ft cam w/Crane roller tip 1.5 rockers
GM HEI w/MSD coil (locked mech adv)
1-5/8" long tube headers 2.5" custom built dual exhaust
Custom self built dual "turbo" mufflers.
TH-350 w/B&M holeshot 3600 converter
4.10's w/Auburn posi +Air-Lift Drag Bags
M/T ET Street/Sportsman Pro tires
11.92@115 1.60 60ft
Old Nov 13, 2008 | 02:20 PM
Car: '84 Z28
nice nice, i like the wheels coming of the ground! love it
Old Nov 14, 2008 | 02:13 PM
doc221978's Avatar
Car: '81 Z-28
I guess I have a little more to do..... Skinny has more weight and less cam and carb then me, and the same times. He does have slicks though, so that may make up for it. I'm at 3340 with driver and 94 octane. I think his carb and cam are much more street friendly, and responsive. I have a lt1 cam out of a police cruiser i have been thinking of grinding the end on and installing. It would put me somewhere between 330 and 350 hp though, and my carb is already to much.... real overkill then.
A friends setup for you..... I don't know the power though
383 stroker
880 block
6.0 rods
9.6:1 comp
xr252hr cam
Qjet.... stock tune still. he's only adjusted the idle.
gmpp intake with a spacer
four speed with creeper
14 bolt posi, with 3.08 gears
I'm not sure if the engine caused it, but he cracked the ring gear in the rear end the day after we put in the engine. This engine is in a 1-ton truck and will tow almost as good as a desiel.
Old Nov 15, 2008 | 08:17 PM
Hog's Avatar
Hog
Is that LT1 cam out of a B4C Camaro or 9C1 Caprice?
If its out of the Caprice it will be 192/197 .412/.427" on a 112ºLSA(L994.3V8, Vortec 305/350cam)
B4C will be 210/208º.447"/.459"(depending on year)
Small indeed. Or is that what you want to do, downsize?
peace
Hog
Old Nov 16, 2008 | 07:22 AM
skinny z's Avatar
How did you come up with your 10.24:1 CR?
Head gasket?
Are you zero decked?
Old Nov 17, 2008 | 03:56 AM
doc221978's Avatar
Car: '81 Z-28
I don't have the stock style dished pistons in there. If I remember right the guy that did my machining said it was 0.025 deck, and a 0.032 head gasket. It was an older guy that has been doing this for 40 years.... I told him my goals, and he gave me part numbers to order. I used an online calculator to figure it out. The pistons I used were supposed to be 10.63:1, but it didn't come out to it. I don't know how the manufacturers figure out their numbers.
As for the cam, it's a 9C1. I don't want to downsize that far, but I think a step or so smaller would be a little better. My car is a little worse on low end then I'd like for a daily driver. I thought i could get away with going with a bigger cam then I should, since I was useing a roller. It's still a daily driver with that cam though.
Old Nov 17, 2008 | 04:07 AM
doc221978's Avatar
Car: '81 Z-28
The oil pump had given out, and it burned up a couple bearings. It had 40k miles and the cylinders still looked good. The entire rotating assembly got replaced. Could you imagine using them pistons in a performane engine? That can't be over 9:1 at best. I tried loading a pic of it when I had it apart the first time, but It's not working for me right now.
Last edited by doc221978; Nov 17, 2008 at 04:11 AM. Reason: Tried to attach a file
Old Nov 17, 2008 | 07:04 AM
skinny z's Avatar
It's difficult to get an accurate number for your static and dynamic compression ratio without knowing the piston type. If I use the 282 cam (installed on a 106 CL) with your piston deck, head gasket, rods etc and use my pistons ( flat tops with 5cc valve reliefs ) I manage a 9.88:1 static compression ratio. That would be fine if your cam didn't produce a dynamic compression ratio of 7.75:1. Although a little on the low side that's assuming you don't have more piston relief and that the cam has been installed and degreed correctly.
Finding out what pistons you have will help to determine if your comp ratio is just too low for building low engine speed torque.
Old Nov 17, 2008 | 11:10 AM
doc221978's Avatar
Car: '81 Z-28
It's been a while, and I can't find the online calculator I used. The pistons are a .150 dome. I know that raises the compression, but I also know that not everything I find on the net is right.
I don't get the differance between static, and dynamic. Are you talking about how the higher duration bleeds off pressure?
I appreciate the info.... I have built a couple engines after all the machining was done, but I have always used combinations that I have seen others use with success.
Old Nov 17, 2008 | 11:51 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
I have Vortec Style heads....
Most of the mods are in signature.
I have 9:1 CR and the factory dual cats with the facotry cat-back (except dented Borla muffler) So thats hurting me.
TPIS ZZ9 cam specs are 0.515 in 0.554 ex with the 1.6 rockers. 212/226
She shifts about 5400rpm and runs a 13.4@102 mph corrected to sea-level
Old Nov 17, 2008 | 01:51 PM
doc221978's Avatar
Car: '81 Z-28
I just read for a while on dynamic compression. It took a little while to understand. I figure I have about 8.91 DCR. It seems as if 7.5-8.5 is the best. My math has to be off though. I am thinking a high lift and shorter duration.
Old Nov 17, 2008 | 02:42 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I'm going with a 350 .030 over, Keith Black KB-193 -12cc D dish pistons, eagle rods, new Scoggins/Dickey vortec heads, comp pro magnum rockers, Edelbrock vortec TPI base, 22lb injectors, L98 cam, to go along with my hooker headers and cat back. The motor will be backed by a T56 and 3.73 rear. I'm hoping for around 275-300 hp at the wheels.
Old Nov 17, 2008 | 05:09 PM
skinny z's Avatar
This is the article I refer to and there is a link to the calculator I use in it.
http://www.empirenet.com/pkelley2/DynamicCR.html
If you had the dome volume ( not height ) then you could get an accurate idea of how much static compression you have. From there you either: Change the SCR to suit the cam or change the cam to suit the SCR. Ultimately, you are trying to achieve the highest dynamic ratio to meet your vehicle requirements.
Old Nov 17, 2008 | 07:53 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
ahh, I gotta get in on this. specs in the sig, but here's the main:
4 bolt 383 10.75:1 CR
L31 Vortecs w/ ported exhaust
CC XE274 230/236 @ .050" .490" 110LSA
HSR w/ 30lb inj
MegaSquirt II V3.0
I remember reading an article in Chevy Hi Performance or Super Chevy, one of those, with a 383, same cam, same heads (bone stock), Edelbrock intake and 750 carb and IIRC it put down like 420hp and 450 ft/lbs at the flywheel, Ima see if I can find that thing laying around here. In my opinion, if you're going Vortec and dont wanna use a roller cam, XE274 is pretty stout and will yield damn good numbers. I can't wait to see what the HSR and MegaSquirt bring me
Old Nov 17, 2008 | 08:43 PM
skinny z's Avatar
Maybe one of these?
http://www.carcraft.com/techarticles...ne/index1.html
http://www.popularhotrodding.com/eng..._manifold.html
http://www.popularhotrodding.com/eng...ine/index.html
Have you checked out Orr89RocZ and his 383 HSR?
Old Nov 17, 2008 | 09:00 PM
spills's Avatar
Car: 89 RS
Ya, me and him have talked a little. He's running a different cam than I am, and I can't remember if he's running Vortecs or not.
That carcraft looks like it might be it, either that or they did a build up similar to CHP. I coulda sworn I read it in CHP, that's the only mag I have a subscription to.
Old Nov 17, 2008 | 09:19 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Stock Vortec heads out of the box
.060 350
LT-1 style rods
Forged Flat top 4v pistons
Lunati Bracket Master .480 lift cam
Proform Roller Rockers
RPM Air Gap
750 Holley Vaccum Secondaries
t-5 with 4.10 gears
290hp/330tq
12.56@110
Old Nov 18, 2008 | 03:52 PM
skinny z's Avatar
.060 350
LT-1 style rods
RPM Air Gap
t-5 with 4.10 gears
290hp/330tq
12.56@110
Do you know your race weight?
60' time?
Slicks?
That's quick for what appears to be a mild combination.
Old Nov 18, 2008 | 09:32 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Its a full interior Z28. Manual windows, etc. T-tops. Only thing missing in the car is the spare tire and floor mats.
1.69 60'
If I remember right it was on a set of worn out Sportsman Pros'. Now I will say my co-worker ran this time and my best was a 12.7x but the setup ran it. After busting 2 sets of gears in a month I went easy on the car and Its been sitting for a few years.
Old Nov 18, 2008 | 11:49 PM
skinny z's Avatar
Which differential? I've busted a pinion myself and am considering an upgrade.
1.69 60' isn't too shabby. What's your launch rpm?
Old Nov 18, 2008 | 11:59 PM
skinny z's Avatar
[QUOTE=spills;3951486]Ya, me and him have talked a little. He's running a different cam than I am, and I can't remember if he's running Vortecs or not.
QUOTE]
AFR 195's. Maybe the best small block heads going.
Old Nov 19, 2008 | 10:28 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Good old 10 bolt with way too much money in it . Eaton Posi, 28 spline axles, rear axle cover and brace kit. I would either hold the rpms about 3000-4000 and then stab it.
Old Nov 19, 2008 | 03:14 PM
JohnBlazeLTZ's Avatar
Car: 1993 Caprice LTZ
Engine: 350 TBI
Transmission: 4L60 (700R4)
I was hoping to see some pics in this thread...
Old Nov 19, 2008 | 03:22 PM
spills's Avatar
Car: 89 RS
here ya go. Few months old, car's come a long way since.
Attached Thumbnails POST YOUR VORTEC SET UP!-sany0137.jpg   POST YOUR VORTEC SET UP!-sany0129.jpg
Old Jul 19, 2009 | 09:08 PM
skinny z's Avatar
Still interested to see what the old Vortec heads are running.
Anything new?
Old Jul 20, 2009 | 04:28 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
i have vtec. i fail =[
Old Jul 20, 2009 | 11:02 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Old Jul 20, 2009 | 11:03 PM
Engine: 355
1978 350 2bolt main block.GM steel crank, GM powder metal rods, TRW 2256 30 over,forged flat tops, Comp Cams 450" lift rule cam,Z28 valve springs, stock rocker arms. three angle valve job on 062 castings.Holley 3310 on performer rpm intake. made 462hp and 440ftlbs on Stuska Dyno.
Old Jul 21, 2009 | 07:08 AM
skinny z's Avatar
Wow!
Old Jul 21, 2009 | 10:37 AM
Engine: 355
Took the same engine and changed the cam to a Erson E110030K
specs>> 284/284 218/218 .458/.458 114. Killed the power made 375 HP and 420TQ. Engine runs alot smoother and works well in my IROC with 700R4.
Old Jul 21, 2009 | 01:59 PM
skinny z's Avatar
Interesting. Those are the same cam specs ( w/ 110 LSA) as the Clevite cam I was using prior to the roller I use now. That little cam managed a 13.2 @ 106 mph in a 3700 lb car.
The .450" lift rule cam must have had a ton of duration to make those power numbers. Impressive.
Old Jul 21, 2009 | 03:33 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
4 bolt main block
bored .030
Scoggin-Dickey large tube TPI vortec intake
Large tube runners
ported Plenum
GM Fastburn Heads
52mm BBK throttle body
1.6 GM full roller rockers
26 lb. ford injectors
LT4 Hot Cam
Hooker Shorties
5 speed
Aluminum Driveshaft
3.73 Posi
Next Step is to Stroke It
Old Jul 22, 2009 | 01:21 PM
Engine: 355
Thats one reason I changed the cam, the duration was so high that the ramp rate was very agressive and may not last long on the street.
Old Jul 22, 2009 | 11:22 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
Originally Posted by F-BIRD'88
406 ci
cast GM 400 crank
KB 168+.030 pistons
GM 5.7 rods
9.8:1 cr
11.92@115 1.60 60ft
Get a REAL Converter in it, and it'll probably pick up a 3-4 tenths and some MPH....Good possibly go some 11.50's, maybe some high .40's at 116-117....
...What are your 1/8 mile ET's and MPH?
Old Jul 23, 2009 | 08:44 AM
skinny z's Avatar
Besides wiping out that flat tappet Clevite cam I has been using, I'd always wanted to go to a roller profile. I could get those fast acting lobes and benefit from the better than average flow rates of the Vortecs at about .5'' lift.
With the 1.6 rockers I'm in the .530"/.540" range and can still keep duration around 224/230*. Excellent street manners, nice lope at idle and great gas mileage.
I just want to go faster. I think 12.5's are in this setup.
That's why I'm checking other Vortec combinations.
Old Jul 24, 2009 | 06:55 PM
  #42
Engine: 355
sounds like your on the right track. I may do something like that myself.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
