Has anyone dropped in a motor with headers attached?
Old Nov 11, 2008 | 10:11 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I would like to put the headers on while on the stand and drop in in if its possible.
I know you need to jack up the motor when its in the car to install them....
I have the Headman 1 5/8" shorties (part no. 68470) with no coolant lines at all or any heater or A/C box.
Old Nov 11, 2008 | 10:20 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Has anyone dropped in a motor with headers attached?
Shorties should go in. Long tubes won't.
Old Nov 11, 2008 | 10:22 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I figured the LT's wouldn't and the shorties would be close. Does the fact the motor needing to be jacked up (if still in the car) play into anything?
Old Nov 11, 2008 | 10:45 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If the left side header slants forward it will not go in with the motor.
Old Nov 11, 2008 | 11:05 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
See picture in my vBGarage. That's the way it looked just before it went in.
Old Nov 11, 2008 | 01:51 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
N/M
I see the pass header on but cannot see the drivers side. Was that one connected as well?
Old Nov 11, 2008 | 02:09 PM
five7kid's Avatar
Yes, both sides were attached. I even had the spark plugs installed so I wouldn't have to hassle with that after the engine was in.
Old Nov 11, 2008 | 04:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I did it with those exact headers a few months ago. I did it alone, with a trans attatched. Aside from the fuel line just behind the pass side strut tower that I crushed, it wasn't too bad. Would go alot better with help though.
Old Nov 11, 2008 | 04:58 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
i was wondering this as i will be swapping in a new motor soon i was thinking loosely bolt the headers on so they can shimmy around to fit in and then torquing em down when the motors in
Old Nov 11, 2008 | 09:53 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Nice. Thanks guys. I'll be sure to post with my success in a week or so!
Old Nov 12, 2008 | 09:49 AM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
I just put my 350 in with flowtech shortys and it slid in with ease did it my self too.
Old Nov 12, 2008 | 09:55 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
I'll give it a shot, what can it hurt, right?
The only thing that got me was, at least with my Headman's, I had to jack up the motor on the drivers side when the motor was still in the car.
Old Nov 12, 2008 | 10:25 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I did it with those headers.
Need to remove the steering rod, and be very careful of the power brake MC. Otherwise you're laughing.
Old Nov 12, 2008 | 10:57 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
That'd be my luck man.
Old Nov 13, 2008 | 09:06 PM
Air_Adam's Avatar
Really? I didn't have to remove anything (except that fuel line that I SHOULD have moved outta the way lol) to get it to drop in with headers bolted up tight to the engine. And that was by myself in the garage with the trans attached too.
But yes, be very careful around the brake MC, it gets very close to that 600lb anvil you are swinging around, and it would only take a small hit to f*ck it all up.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Elliswon
Aug 10, 2015 12:33 PM
