Solid motor mounts
Old Nov 21, 2008 | 08:18 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Solid motor mounts
Has anyone used solid motor mounts on a street car? They say it helps with transferring power, but what kind of negitive effects does it put on the car when you are not racing it? Is it a vibration issue?
Does anyone have recommendations for motor mounts?
New motor is going in, and I don't feel the 17 year old originals should go back in. I have a new poly mount for the transmission that came with my Spohn torque arm and crossmember.
The regular replacement mounts I've seen are just the rubber replacements, you have to split the shell open, has anyone seen a complete replacement mount?
Old Nov 21, 2008 | 10:47 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Solid motor mounts
Solid motor mounts dont dampen vibrations. Just buy some poly ones. I have them and they work great.
Old Nov 21, 2008 | 10:49 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
If it's a street car, go with poly. All you need is the ploy insert. You split open the clam shell and slide it in.
Old Nov 21, 2008 | 10:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I've run the Moroso solid mounts in an '85 Camaro V8, and that engine had been balanced, it wasn't just as GM built it. I really have no complaints. That car had a 700R-4 on a poly mount, in case it matters.
Old Nov 21, 2008 | 11:28 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
The term rattletrap comes to mind. I would assume that the smoother the engine runs the less vibration you'll transfer to the car. For a street car there is no reason to go solid. Personally I would go poly if I could find 'em.
Old Nov 21, 2008 | 11:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
When you go to the parts store and buy yer basic rubber mounts they come in new shiny metal clamshells.
I think I just used those... With a poly tranny mount.
You can buy that, drill out the rivets, and put in a poly mount if you like instead.
Most people who run solid mounts wouldn't recommend it on the street, if you want to keep your fillings in your mouth...
Old Nov 21, 2008 | 12:46 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Thanks! Being that we use 3 out of the 4 possible bolts on the mount, anybody dealt with the clamshell wanting to come apart with the poly in it and the rivit poped?
Old Nov 21, 2008 | 01:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You drill the rivet out when you put the poly insert in.
Old Nov 21, 2008 | 01:18 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Yeah, with out the rivit, and only the one bolt on the one side of the mount holding the clam shell together, I would think this would weaken the mount 9without the rivets, has anyone had problems after changing out the insert?
Old Nov 21, 2008 | 01:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The bolt is orders of magnitude stronger than that pathetic little rivet.
Old Nov 21, 2008 | 03:49 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
been running solid mounts for 4 years now.. just vibrates more.. feels better on launch and shifts since the rubber mounts arent soaking up torque..
i have no complaints..
Old Nov 22, 2008 | 09:50 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Nope, working good for three years now.
Old Nov 22, 2008 | 11:18 PM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I've been running Moroso solid mounts for a few years now, I drive my car every day. I didn't even notice a difference over the stock rubber ones except at high RPMs then it vibrates a little
Old Mar 20, 2009 | 12:01 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
what grade bolts do you use on solids?
#8 or 10.9s?
im using #8s but havent run the motor yet you think they are good enough?
Old Mar 20, 2009 | 01:13 PM
5678TA's Avatar
Car: 1984 Trans Am
#8 or 10.9s?
grade 8 is more than enough till 9's.. then i would worry a little.
Old Feb 1, 2013 | 07:02 PM
bllwltr's Avatar
3 80's trans ams, one stock, one with dome pistons and rubber mounts, and now trying solid mounts on a 82 ho 355 780 holley and a 3800 stall, everyone says it will help on a lunch, will let everyone know. hope it don't twist the car. My question is just jack it up under the 6" crank is that the best way
Bill
Old Feb 1, 2013 | 08:18 PM
basiccamaro's Avatar
In the past I had a pretty healthy 454 +.030 with factory rectangular port LS6 heads in a 1969 Chevelle SS. I used a solid mount on the left side where the torque pulled up on it, and a stock one on the right where the torque sqashed down on the the rubber. It worked very well. If the rubber gave any, the left mount could pivot just a little bit on the lengthwise through- bolt. I ran both a 4-speed and a Turbo 400 in the car, and honestly, I think that I could have run both of them solid with no problems at all.
Old Feb 1, 2013 | 10:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Ran solids on a DD car. It wasn't to bad at all but I do have a higher level of crazy than most.
Old Feb 1, 2013 | 10:53 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is what I put in mine. I will never use the stock rubber mounts again,and since its a DD street car solids are not necessary.
http://www.oreillyauto.com/site/c/de...d=engine+mount
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
