SPUTTERING PROBLEM 1988 GTA
Old Dec 2, 2008 | 09:10 AM
firebird's Avatar
Just put a new engine (305) in my 1988 GTA. However, I'm experiencing what I consider a small problem. Upon start she runs fine, but when I put it in gear and pull off she begins to sputter as I accellerate. After about 5 minutes of driving the it clears up and runs fine. This happens even if I let the car get to its operating temp. before driving off as well. It seems to me that the car maybe tempermental or maybe the injectors are not operating correctly. I used seafoam and it cleared up a little bit, but it's still smuttering a little, but less than before. I have new wires, plugs, new fuel pressure regulater, new fuel pump. thanks in advance for your help.
Oh, by the way has anyone experienced a humming sound coming from the fuel pump when our cars get hot? My mechanic thinks my exhaust sysem is too close to the gas tank. I never had this problem before with other catbacks. I currently have the 3" flowmaster catback system.
Jeff
Old Dec 2, 2008 | 10:00 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: SPUTTERING PROBLEM 1988 GTA
Not sure about your sputtering, probably not getting enough cold-start-enrichment. How old is your fuel pump?
Old Dec 2, 2008 | 10:05 AM
firebird's Avatar
Attilla, the fuel pump is less than 2 months old...
Old Dec 2, 2008 | 10:22 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If I'm not mistaken, the '88 should have a 9th injector, for cold-start enrichment. That's the next thing I'd investigate.
Old Dec 2, 2008 | 10:37 AM
firebird's Avatar
Thanks Attilla. I'll look into the 9th injector cold start enrichment. Hopefully, that's a simple fix...
Old Dec 2, 2008 | 11:25 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
while running pull the injector plugs off the injectors one at a time.
if there is no change in the way the engine runs then you pull that plug and check for spark
if you dont have a tpi motor under the hood then chances are it is not a gta and you should fill out your profile so we can help with your diagnoses
Old Dec 2, 2008 | 12:11 PM
firebird's Avatar
Jamon,
It's definitely a TPI motor, as it has the same block casting numbers (14093627) of the old 5.0 that I pulled out of the car.
Old Dec 2, 2008 | 02:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That same block casting was used for carb, TBI, and TPI engines.
Old Dec 4, 2008 | 11:03 AM
jamon8's Avatar
Engine: 350 tpi
pull the injecter plugs one at a time while it is running and there should be a noticalble change in the running of the tpi
if there is not then pull the spark plug out and check the spark plug wire
Old Dec 4, 2008 | 12:10 PM
firebird's Avatar
Will do. Thanks a lot Jamon8
jhawkeye
May 25, 2022 06:33 PM
stalkier
Aug 21, 2015 01:54 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
gta power
Aug 13, 2015 06:15 AM
Randomtask2
Aug 13, 2015 01:57 AM
