Air Cleaner Replacement Custom
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
HELP!! Air Cleaner Replacement
Ok so I bought a Mr. Gasket universal air filter 14" x 2.5" with the stock air filter that came with it, looking for a K&N to fit now with a 3" height instead of 2.5 but anyways before that I need help on understanding where some placements need to be put and how to configure this in exchanging it for my other air cleaner that had only 1 snorkel.
(I want a x-stream as well but where could I just find the top cheaper?
http://www.ecklers.com/product.asp?p...LL-_-42203-_-X
All I need now is the top peice and since the cleaner is already chrome i'd like to get the chrome trim if possible)
[Original]
[Replacement]
What I'm looking to do is see where all these sensors should be placed and the vacuum pump and what not. I have all the items circled in green in the next following pictures. If anyone could explain to me where I should place these without having a "check engine light" or anything wrong with it that would be great. I noticed in the Mr. Gasket one there is a spot for one sensor that's circled in red, but where do the rest go?
[Original Air Cleaner Spots "in red"]
[Replacement Spot "in green"]
[Original]
[Replacement]
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: Air Cleaner Replacement Custom
in the last pic, that is the knock-out for the breather. In the next pic up, the IAT sensor will need to be installed in the new housing, and I believe the other one is the thermac switch, which is what controls the flap in the snorkel so, that would now be unnecessary. someone correct me if I'm wrong. hope this helps
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Transmission: 4L80E/4L80E
Is your universal air cleaner a drop base? It might be an optical illusion because of the angle of your photo, but it doesn't look like it.
The "sponge" thing isn't needed if you mount the breather to the knock-out hole in the aftermarket base. You just need filtered air, and the knock-out is inside the filter, while it's outside the filter on the stock air cleaner.
The X-stream lid (and those like it) will sit in the hood blanket, so it doesn't really do any good without a cowl hood.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Actually, now that I look at it again, it looks like a drop base, like the factory air cleaner.
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
you could also get a clamp on breather for your crankcase so you dont have to knock another hole it the breather base
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I found out that i could get a pushin breather
works very well thanks!
works very well thanks! Thread
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
