fuel pressure regulator
Old Dec 27, 2008 | 09:49 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
HOW did u guys get ur regulators from leaking gas? i used teflon tape and everything, and its leaking at all 3 ports
Old Dec 28, 2008 | 01:11 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: fuel pressure regulator
on???? tbi? tpi? carb?
Old Dec 28, 2008 | 10:24 AM
Engine: 355
carb. got one going in and one out. one plugged till i get my nos
Old Dec 28, 2008 | 04:01 PM
rodrob1961's Avatar
Car: 2003 SILVERADO /86 IROC/85 S10
Someone correct me if I'm wrong, but shouldn't there be a return line? I would think that the pressure that the carb is not using would be pushed through the return line, therefor relieving the pressure on the other two lines.
Old Dec 28, 2008 | 04:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, it needs a return line.
Old Dec 28, 2008 | 06:56 PM
Engine: 355
i got the holley one thats a dual feed, has no return style regulator. one in, 2 outs. how do i get them to seal?http://static.summitracing.com/globa.../sum-g3136.pdf
Old Dec 28, 2008 | 07:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What pump are you using that with?
Old Dec 28, 2008 | 07:08 PM
Engine: 355
http://store.summitracing.com/partde...5&autoview=sku my combo
Old Dec 28, 2008 | 09:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What pressure are you set at?
Old Dec 28, 2008 | 10:09 PM
Engine: 355
im set at 7psi. im not having issues with that i need to get the gas from slowly leaking out
Old Dec 29, 2008 | 12:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What fittings did you use?
Old Dec 29, 2008 | 09:56 AM
Engine: 355
http://store.summitracing.com/partde...5&autoview=sku. they looks identical to these, and using a brass plug. should i use teflon pate to seal? i used the tape and it aint working. i left two threads before i started the teflon tape.
Old Dec 29, 2008 | 02:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Teflon tape isn't really a good thing to use on fuel fittings, but it still should have worked. Try the paste instead.
Old Dec 29, 2008 | 05:14 PM
Engine: 355
ya i just went and got some. gna try some after work tonight. hope it works
Old Dec 29, 2008 | 05:38 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
do the fittings require a almost clear like plastic gasket that sits on the tip like the TBI units ?
Old Dec 29, 2008 | 05:43 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
NPT Fittings on the common deadhead pressure regulator - no.
Old Dec 29, 2008 | 07:32 PM
Engine: 355
y? i have seen numerous people using them. its not pouring out fuel but enough to make me wory bout a fire. lil trickle basically
nope
Last edited by billybob6110; Dec 29, 2008 at 07:33 PM. Reason: Automerged Doublepost
Old Dec 29, 2008 | 07:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I was talking about the fittings requiring a special seal. Not your setup.
Old Dec 29, 2008 | 08:43 PM
Engine: 355
sry thats my fault mis read
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
