Oil Leak Driver Side Header / Above oil filter
Old Jan 3, 2009 | 02:32 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have a oil leak that is running down from the back of my header/engine somewhere. It is running down above the oil filter. It runs down and drips off my tranny pan in the front. Anyone know what it is. I will get pictures tomorrow.
Old Jan 3, 2009 | 03:39 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Oil Leak Driver Side Header / Above oil filter
Distributor seal or rear china wall would be my guess.
Old Jan 3, 2009 | 09:05 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
check the oil press. sensor . it's above the oil filter . when re-sealing/replaceing be careful of old brittle plastic elect. connector . good luck .
Old Jan 3, 2009 | 09:21 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
go to the car wash and clean the motor and then have a look
unless you want my best blind guess
Old Jan 3, 2009 | 12:09 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
It looks like it is coming from the distributer area. How hard is it to fix. And what is the rear china wall? It isn't coming from the sensor. I know that for sure.
Old Jan 3, 2009 | 12:19 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
China wall is where the intake manifold and engine block mate together; the area that runs across from each cylinder bank at both ends of the block.
If it's not coming from the intake manifold or the sensor, it's either coming from the distributor seal (it's a flat gasket) or the valve cover.
Old Jan 3, 2009 | 12:23 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How hard is it to fix the distributor leak?
Old Jan 3, 2009 | 01:56 PM
ljnowell's Avatar
Remove distributor and reinstall with new gasket. Clean it off good and make sure its not the intake gaskets leaking. The area between the heads where the intake meets the block is prone to leakage. There are these crappy end seals that come with intake gaskets that always leak. We usually throw these away and put a nice bead of RTV on it.
Old Jan 3, 2009 | 02:15 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Distributor hole has little or no oil presence. Most likely there is a full oil pressure tap next to the dizzy on the back of china wall that is leaky. As others have pointed out china wall intake manifold gaskets are prone to leak. When I re-install intakes I drill 3/16 holes into china wall every couple of inches for RTV to grab to. Instead of end gaskets I use ~5/16" bead of black RTV on the china walls. Give 24 hours for RTV to fully cure itself before putting engine back into operation.
//RF
Old Jan 3, 2009 | 02:26 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I cant figure out how to take out the distributer... I have searched but cant find anything. Do I have to mark anything or what? I have the dizzy cap off but I cant figure how to get the rest of it off.
Old Jan 3, 2009 | 03:02 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
There's a bolt down by the base of the distributor, attached to the intake. It's the hold down clamp bolt. Dizzy isn't going anywhere until you remove that. Would be wise to index the rotor so you know where it's pointed when you reinstall so you can maintain correct firing order. Once you've done those 2 things, dizzy should lift right out.
Old Jan 3, 2009 | 03:11 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That bold is going to be a pain to get to. And this is why I hate this damn Super Ram. It gets in the way of everything.
Edit: I can't even see the bolt.
Old Jan 3, 2009 | 04:04 PM
ljnowell's Avatar
Are you sure its leaking out of the distributor? Take some brake clean and hose it all off and clean it all. Nice and clean. Run it, drive it, see if thats where its leaking at or not.
Old Jan 3, 2009 | 04:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
OFF TOPIC:
I feel your pain. Try replacing a crank angle sensor on a V6 W-Body. It has to be done via Braille method. Even with the engine rotated over.
Can you feel the bolt? A universal socket, a long extension and a ratchet might help getting to the hold down bolt. Feel for the bolt with one hand and manupulate the ratchet with the other.
Old Jan 3, 2009 | 05:48 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, distributer is out. Where is the gasket supposed to go?
If it isn't that, what is this oil port you are talking about?
Old Jan 3, 2009 | 08:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
On the distributor, there's the collar that rests on the intake. Slide the distributor seal over the bottom of the dizzy and up against the collar. The seal gears sandwhiched between the collar and the intake manifold.
As for the oil port you're looking for: http://www.transamws6.com/pics/transam/piston02.jpg
See the right angle NPT fitting on the rear china wall? That's what you're looking for (you might not have the fitting, but that's the ports location)
Old Jan 3, 2009 | 10:50 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Okay, not seal on the distributer, but I don't think it was really leaking.
I will check the port. I need to get my car going as I get my license back on Tuesday. Tomorrow, I am going to check the port and glob RTV on the China Wall, and get the gaskets for the dizzy. Then I have a Sac GTG on the 11th I plan on going to.
Navy8125
Aug 21, 2015 09:32 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
timonator
Aug 11, 2015 09:56 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
