Another "which heads" question.
Old Jan 7, 2009 | 09:18 PM
TRSCobra's Avatar
Car: 2018 Corvette Grand Sport Z07
Transmission: C7 Z06 TR6070
Only this time I'm the one asking it!
I'm going on pre-deployment leave (army) in may and I want to have some fun at the track in my two weeks home. So I've come to the conclusion. I need 2 things: A higher stall converter and some good heads.
I've got a reman. 350 bored ~.060 with stock internals except for a cheap summit 1103 cam. I ran a 14.1 with my current setup. What heads, combined with a 2500 stall torque converter, will get me well into the 13's?
Keep in mind I really don't have time to do much else to the car, so a simple bolt on deal is a must.
Thanks.
Old Jan 7, 2009 | 10:16 PM
ljnowell's Avatar
Re: Another "which heads" question.
Thanks.
What is your price range? I had a friend who recently had a good experience with the patriot aluminum heads.
Old Jan 8, 2009 | 12:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.sdparts.com/product/SD806...formerRPM.aspx
Old Jan 8, 2009 | 12:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
For the price of that kit, you can do fairly well with most of the entry level performance castings offered up I would think. Judging from the posters sig, he already has a good intake.
Like LJ asked, what is your budget? As well as Patriot, Dart, World, Brodix, and RHS also have good stuff at an affordable price.
Old Jan 8, 2009 | 08:25 AM
five7kid's Avatar
Sell the intake you have to offset the price of the package.
Old Jan 8, 2009 | 11:18 PM
TRSCobra's Avatar
Well, I'd like to keep it in the ~$1k range. I considered vortec heads, but I really don't want to get another intake. While that is a good price for that head and intake package, wouldn't I get better performance and a similar price with a non-vortec, aluminum head setup?
Old Jan 8, 2009 | 11:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
You probably won't find alum's for the 1k range, maybe 1200 or so, not certain. But irons, yes. Better out of the box performance than Vortecs.
Old Jan 8, 2009 | 11:32 PM
TRSCobra's Avatar
I'm not dead set on a $1k limit; I'll spend $1500 if I have to. I just want to take a 13 second timeslip to Iraq with me.
Old Jan 8, 2009 | 11:35 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
A better cam with the heads would go a long way, then.
Old Jan 8, 2009 | 11:47 PM
five7kid's Avatar
If you can't run 13's with that sdparts head/intake kit and a cam like a Comp XE268 or XE274, it isn't the engine's fault.
Remember that sdparts Vortec head/intake kit includes gaskets, bolts, & self-aligning rockers as well. That stuff will add at least $50 to any other heads you get.
I don't know what shipping will be on the head kit, but I bought an LS7 clutch kit from them, which included a new flywheel, and shipping was only about $18 or so.
Old Jan 9, 2009 | 12:20 AM
TRSCobra's Avatar
I'll upgrade the cam another time, as I just installed this cam and I'm not looking forward to another cam swap (even though I'll be halfway there with the heads and intake off). Wouldn't some cheap stamped steel 1.6 ratio rockers on the new heads do the trick for the time being?
Also, I want to keep my 600 cfm carb on there and not be too undercarbed.
Old Jan 9, 2009 | 01:13 AM
five7kid's Avatar
1.6's would help a little bit, but not significantly.
Old Jan 9, 2009 | 11:24 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Summit has these at a pretty good price right now.
http://store.summitracing.com/partde...5&autoview=sku
Edelbrock 60899 RPM cylinder heads for chevy.
Cylinder Head, Performer RPM, Aluminum, Assembled, 64cc Chamber, 170cc Intake Runner, Chevy, 302/327/350/400
Old Jan 10, 2009 | 01:27 AM
ljnowell's Avatar
While those are good street heads, IMO you can get a lot better for that money.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
