How to make TPI flow good up 5000
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
hi,what kinds of things can i do to make tpi flow nice only up to 5000(dont need higher) since it peaks at 5k on a 350ci...i already have a vortec base..and on a tight budget...can i just port the snot out ouf the stock runners and plenum,vortec base?
thx bill
thx bill
Car: '91 Camaro, 90 Formula
Engine: 355 carb, 305 TPI
Transmission: TH 350, 700R4
Re: How to make TPI flow good up 5000
I'm guessing since you have a vortec base you already have vortec heads? If you do that should have been a nice jump from the stock heads.
I dont know about the vortec base, but theres not a lot you can do with the stock runners. They're very thin from the factory and doing anything but poilshing out very minor casting flaws will have you cutting through the wall of the runner. I learned that the hard way
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
Port the plenum, new runners. SLP, EDELBROCK. First tpi systems work good from what i hear but they go for $1000. LTR setups like the tpi aren't ideal for high rpm engines but you can make them go as high as 6000rpm and still make good power. But it's not cheap.
Transmission: 4L80E/4L80E
Car: 89 Formy
Transmission: A4
Car: 1983 G20 Chevy
Transmission: 4L60
You need prom tuning if you are not pulling 5,500+ RPM with ease, even with the factory L98 cam. As long as you have a good exhaust with GOOD headers, you should be making power to 5,500 rpm all day long.
I have TPIS oversize long tube runners and partially siamesed SLP old design runners. I will be trying both soon just to see which runs best. Honestly I dout the SLP runners are going to be the best with the stock 1,600 rpm converter and 3.08 gears, but the TPIS runners should take advantage of the 6,000 rpm power potential these heads and the cam have.
Fuel Shut-Off is 5,800 rpm in this video.
What kind of gains did you see when you installed the vortec's? I'm curious because I always thought about doing that on my 87 formula.
Car: 1990
Axle/Gears: stock
My engine 350 CID Vortec TPI EASILY pulled WELL past 5,000 rpm and made power till around 5,500 rpm with the STOCK intake runners. Torque was falling off, but the HP curve was FLAT from 4,500-5,800+.
is that your shut off?
Car: 1983 G20 Chevy
Transmission: 4L60
"But my ET is best when I shift at xxxx RPMs." That's a different issue. You should shift so that the engine is at peak torque in the next gear, which means you might need to shift at a different point 1-2 than you do for 2-3.
Car: 1983 G20 Chevy
Transmission: 4L60
Exactly. You weren't making any more power above 4500 RPMs.
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
If you go quick you can get it for $825 https://www.thirdgen.org/forums/grou...-intake-2.html
Plus it comes with more than alot of systems do so its worth it IMHO.
other than that, just get new runners and base and start porting.
with 17 inch long runners your never gonna make good power at 5 grand, instead you need to get shorter runners, like how gm did with the lt1, you may loose a little torque, but the hp will rise accordingly, the long runner in a tpi is the main cause while it wont make power at 5k plus
