oil pressure dropping when stopped?
Old Jan 10, 2009 | 01:23 AM
smc332s's Avatar
Car: 1992 Camaro RS
Hi guys and gals,
I am having problems with my oil pressure dropping when i stop when the car gets warmed up and don't know why? It is a '92 305 with about 200k on it. Any info would help thanks.
Old Jan 10, 2009 | 01:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil pressure dropping when stopped?
Chances are your oil pressure sending unit is bad and your oil pressure is fine.
Old Jan 10, 2009 | 01:26 AM
smc332s's Avatar
Car: 1992 Camaro RS
Thanks, i read somewhere about that, is that a hard thing to fix?
Old Jan 10, 2009 | 01:29 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not too hard, you unscrew the sender in the side of the block from underneath and screw the new one in with thread sealer.
Old Jan 10, 2009 | 01:31 AM
smc332s's Avatar
Car: 1992 Camaro RS
Thanks Apeiron, this many miles got me a little worried, i'll try that out tomorrow
Old Jan 10, 2009 | 03:44 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
On my '85 LG4 the oil pressure sending unit was on the drivers side, top, rear of the block, not on the side underneath.
Maybe Apeiron knows something I don't...
Old Jan 10, 2009 | 07:41 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
My 305's unit was top right side of block next to the dist. As is on my current motor (Pre 85 block) Maybe later model is diff? Mine was an 87 LB9. After replacement I had a better reading, but still low. Car had a bad gauge. Found this out by hooking up an aftermarket piece. Good luck...
Old Jan 10, 2009 | 08:41 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
If you're using a cheap FRAM filter, you might want to try changing that first.
Old Jan 10, 2009 | 08:52 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
you have probably already checked but are you using the correct guage to check the oil level? it sounds like there is not enough oil and when you hit the breaks its sloshing around giving a low reading.
yes, that is what happened to me once because im an idiot and did not check to see it was low after an oil change.
the oil can have lost some viscosity because the wrong oil was used or its just old.
i would check those before i started pulling parts off.
Old Jan 10, 2009 | 09:21 AM
Doc_G's Avatar
Car: 87 Trans Am
Axle/Gears: Not enough
Originally Posted by smc332s
Hi guys and gals,
Has the engine ever been rebuilt? Lower end ever been serviced? You might be losing oil pressure when the car idles due to the rotating assembly's age. It also could be the oil sending unit. It should be located above your oil filter, but I warn you now your going to want to buy the 12 dollar socket to make removal a snap. It's similar to the O2 sensor removal socket and trust me when I tell you IT HELPS ALOT. The sensor itself is 30 or so dollars. Try changing it and see what your oil pressure does.
Old Jan 10, 2009 | 01:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
He has a 92
Old Jan 10, 2009 | 02:04 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
He has a 92
Yes, but, since they're both sbc's, I figured that info about an '85 might still be relevant for him.
Old Jan 10, 2009 | 02:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In this case it's not.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
