Air cleaner Clearance issues?
Old Jan 14, 2009 | 08:05 AM
84 camaro z28's Avatar
Car: 84 camaro z28
Engine: 5.7 carbed
Transmission: turbo 350
I'm having issues with my hood hitting my air cleaner when I try to close it. I have an eldelbrock performer intake so its not a high rise, but I would like as big as filter as I can get for more air flow as possible so I was just wondering if the only thing to do is get a cowl induction hood. I would like to see a performer rpm intake on there too. Thanks
Old Jan 14, 2009 | 08:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Air cleaner Clearance issues?
Drop base air cleaner?
JamesC
Old Jan 14, 2009 | 08:10 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Get a K&N exteme top and a 2in air filter and then use a drop base air cleaner like james said and you should flow good and have plenty of room under the hood
Old Jan 14, 2009 | 09:40 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
That's interesting, I had a performer intake on my 305 and it didn't rub. Guess the camaro hood is flatter or ?
I was going to say drop base as well but the others beat me to it
Old Jan 14, 2009 | 10:03 AM
Car: 84 camaro z28
Engine: 5.7 carbed
So that extreme top is that like a separate filter on top too?
Old Jan 14, 2009 | 10:10 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Yup
http://store.summitracing.com/partde...5&autoview=sku
Old Jan 14, 2009 | 12:35 PM
AKATDOG's Avatar
Car: 84 Z28
i too am having the same problem, after swapping my engine, intake, and carb i find out today my filter assembly that i kept wont clear the hood, its touching the air filter by the time the hood lock touches so im guessing i need about 2inces more clearance is this posible with these drop base filters ? also what size 14" or 16" and where can i find them ? Thanks.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
