antifreeze from exhaust manifold bolt?
Old Jan 15, 2009 | 01:21 AM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
i have a 350 4bbl carb, i saw oil leaking from the front passenger side manifold bolt (the one that the smog stuff bolts to, its the closest to the alternator) and i decided to pull it, and as it was coming out antifreeze started gushing out of it? is this normal for the exhaust manifold bolt to hold back water?
Old Jan 15, 2009 | 02:09 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's not "normal", but not unheard of. I had it happen with some World heads when I used 1" instead of 3/4" header bolts.
Old Jan 15, 2009 | 02:32 AM
fychelio's Avatar
Axle/Gears: ????
Re: antifreeze from exhaust manifold bolt?
heads gone? (dumb question but figured id ask anyways) cuz i think i used a bigger bolt too
Old Jan 15, 2009 | 05:30 AM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
Sorry, no it is not supposed to do that. Water coming from those bolt holes means you have punctured the water jacket. A decent machine shop ought to be able to repair it though.
Old Jan 15, 2009 | 12:44 PM
ljnowell's Avatar
Put some sealant on it and put the bolt back in. If it doesnt leak you are fine.
Old Jan 15, 2009 | 01:06 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
With some sealant it should seal just as well as the intake manifold bolts I should think. Should be fine.
Old Jan 15, 2009 | 06:01 PM
ljnowell's Avatar
Old Jan 16, 2009 | 01:07 AM
five7kid's Avatar
Still running the heads. I put a glob of silicone into the bolt hole, coated the header bolt threads with sealant. Works fine.
AussiePr0nCar
Mar 6, 2020 04:04 PM
transaero
Aug 31, 2015 01:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Nj1987
Aug 19, 2015 08:26 PM
timonator
Aug 11, 2015 09:56 PM
