383 piston question
Old Jan 18, 2009 | 09:06 PM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
383 piston question
Can anyone tell me if there is any difference between a normal 350 piston and a 383 piston, besides the trimming of the skirt? I've got a 4-bolt 350 block that was bored to .060" over that I am thinking I would like to build a stroker out of. Only problem is the 383 kits I have found only have pistons for the standard .030" over bore. I am thinking I may just buy some .060 350 pistons and modify the skirts to fit, but I want to make sure this will work. Something tells me the wristpins are moved towards the top of the piston a little on the 383 kit, but I cannot find any info to say yes or no to this. Or anything to show any other differences for that matter. Any info would be appreciated, thanks.
Old Jan 18, 2009 | 09:17 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: 383 piston question
A 383 piston has a relocated piston pin up towards the top of the piston. If you put a 350 piston on there, the piston/rod length will be .250 longer, and the piston will come out of the bore on TDC.
Old Jan 18, 2009 | 10:14 PM
fryer1979's Avatar
Engine: 350; none
That's what I was thinking. Any ideas how to go about buying pistons to fit a .060" over bore? Or should I just call up some tech lines and give then my specs and see what they can find?
Old Jan 18, 2009 | 10:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
+.060" is a standard size, you'll find lots of them in the catalogs.
Old Jan 19, 2009 | 12:23 AM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
You may not see the .060 size advertised in the catalogs, but if you call to order it, then it will not be any problem, and the price will almost always stay the same.
Where are you looking at buying your kit?
Old Jan 19, 2009 | 12:51 AM
fryer1979's Avatar
Engine: 350; none
I am looking at either the Summit or Eagle stroker kits from Summit. Have looked in a few other places as well, but these are the two I've narrowed it down to. In the catalogs though they only advertise the kits coming with .030" pistons. Mostly just curious if a .060" piston would be an option when I order or if I may have to go buy seperate pistons to add to the kit.
Old Jan 19, 2009 | 12:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd have to call and ask if they'd substitute.
Old Jan 19, 2009 | 12:54 AM
fryer1979's Avatar
Engine: 350; none
I know they are a standard size for a 350, that's what my original intent was with this block. I've just not been able to find a +.060" option for a 383 (or rather 388) kit.
Got it, I'll give it a shot. Thanks guys.
Old Jan 19, 2009 | 10:25 AM
bart91406's Avatar
Car: 91 rs
Transmission: th350
Summit Racing is a great place to deal with, and there prices are always fair. but I have seen kits of equal quality, for quite a bit less.
I have dealt with www.cnc-motorsports.com upon many occasions, and they have good customer service, and great prices, you might look into that before you purchase.
Old Jan 20, 2009 | 12:33 AM
fryer1979's Avatar
Engine: 350; none
I've been buying from Summit for years, and have always been happy. Even when they screwed up they were quick to correct. I've never heard of CNC motorsports, but I will check them out, thanks.
Old Jan 21, 2009 | 03:19 PM
blp226's Avatar
Go with the eagle. I have a friend who used the summit and it wasn't so good. My eagle assymbly was pretty sweet.
Old Jan 22, 2009 | 05:21 AM
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
Summit crankshafts are made by Scat (at least the ones i have seen). I have one in my 350 and there isn't anything wrong with it.
Mickeyruder
Sep 2, 2015 02:45 PM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
