ignition keys stuck
Old Jan 20, 2009 | 06:05 PM
87IROCZ53's Avatar
Car: 1987 IROC-Z Z-28 Camaro
Engine: 305 TPI V8
ignition keys stuck
I have a 87 Iroc and the keys are stuck in the run position and the keys are stuck in the car, the ignition wont turn back to the off position so i can pull them out.
Can any one give me a hand?
Old Jan 20, 2009 | 11:49 PM
bigboy123's Avatar
Re: ignition keys stuck
Same thing happened to me...just push the ignition in and out wiggle it, and try to get it to turn back. Thats what i did and it worked... 2 days later my ignition cylinder was locked up...i bought a new one from partstrain.com for about 10 bucks, trust me your going to be better off buying a new cylinder. it only took me about an hour to replace...your going to need a steering wheel puller and a trux driver, but it really isnt that hard to replace.
Old Jan 21, 2009 | 07:24 AM
Fyrstorm's Avatar
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Move the steering wheel and try taking it out. Sometimes there's pressure holding the column in the lock position and you can't get the key out.
Old Jan 21, 2009 | 03:53 PM
50bmgshooter's Avatar
sounds like the shifter lock is out of adj.
try putting the car in neutral or just out of it into drive or reverse but not letting the shifter lock into gear.
Old Jan 26, 2009 | 05:45 PM
87IROCZ53's Avatar
Engine: 305 TPI V8
hey are there any websites that have a diagram that will show me how to replace the ignition cylinder?
RedLeader289
Sep 23, 2015 06:50 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Denricci22
Sep 18, 2015 09:02 AM
TexasMaro
Sep 15, 2015 06:50 PM
383cam
Sep 9, 2015 06:01 AM
