Hissing noise.
Old Jan 24, 2009 | 12:23 AM
blindslide's Avatar
Car: 1984 camaro z28
Engine: LG4
Axle/Gears: stock
Hissing noise.
I recently put new spark plugs and wires in my car,
and now its smoking from under the hood,
and hisses from the driver side by the exhaust manifold/tranny.
could i have cross threaded a spark to get that noise?
would it be a SSSSSSSSSSSSSSSSSSSSSss noise?
Old Jan 24, 2009 | 12:53 AM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: Hissing noise.
The noise you described sounds like a vacuum leak, look around for loose or broken hoses.
Old Jan 24, 2009 | 02:06 AM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
Re: Hissing noise.
it has white smoke coming from under the hood accompanyed by the noise. and i had just replaced the spark plugs....
but i will search around for the source again...
Old Jan 24, 2009 | 02:24 AM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
Re: Hissing noise.
update: also smells like fuel***
Old Jan 24, 2009 | 09:18 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Hissing noise.
I suppose it is possible that you cross threaded that spark plug. You can always pull it out to find out for sure. Was it hard to thread in? You should be able to thread it all the way in with your fingers and then just torque them down. If you had to wrench it all the way you may have thread issues now.
Old Jan 24, 2009 | 06:10 PM
Joes1wood's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 Liter
Axle/Gears: 10 bolt 3.55 POSI
Re: Hissing noise.
That's weird, same thing happened to me. I replaced my distributer(old one's pick up coil fell apart after 200,000 miles). I was timing it, and I forgot to reattach a small hose on the back of the carb after I detached my EST 4 pin connector. I had a back fire through the carb (or a flame out, whatever you call it)
When I started it back up, I had this loud hissing sound that wasn't there before the backfire. Everything is back to semi-normal now, and with the air filter on, there's no hissing.
Odd?
Old Jan 24, 2009 | 09:58 PM
blindslide's Avatar
Engine: LG4
Axle/Gears: stock
Re: Hissing noise.
maybe thats what happened with me, i took a look at the smoke, and its cause i forgot to reattach the oil breather to the air filter.... dummy move on my part....
ill look for a vacumn line, and if not, i gotta put my hand back into that retardedly tight space again and pull the plugs and check them.
they all hand tightened though...
and i know i have the cables right...
would a vacumn leak cause a shake like a missing spark plug?
Old Jan 24, 2009 | 10:32 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
Re: Hissing noise.
after you hand tighting them you still need to torque em...
Old Jan 25, 2009 | 11:58 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
Re: Hissing noise.
Depending on which vacumm line, yes.
theshackle
Sep 17, 2020 08:26 AM
64Chief
Sep 12, 2015 08:05 AM
Randomtask2
Sep 7, 2015 05:06 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mike '91 Z28
Jan 1, 2001 01:55 PM
