416 heads
Old Feb 6, 2009 | 10:25 AM
Sovuf's Avatar
Car: 86 IROC
Engine: Soon 355
416 heads
Short question, can my 416 heads off my LB9 bolt on to a 350 block? I am getting work done to the heads for my 305. Later on though, I am going to rebuild a 350 that is in my garage. Can I use the 416 heads? Thanks guys.
Old Feb 6, 2009 | 11:23 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 416 heads
Yes the heads will bolt up and also assuming you have the right intake to match but its not genrally recomended performance wise.
Old Feb 6, 2009 | 11:24 AM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: 416 heads
should work decently, just watch the compression. ...they would be a step up over camel-hump heads if thats what came on the 350
Old Feb 6, 2009 | 11:28 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: 416 heads
I would not starve a 350 that way...
Old Feb 6, 2009 | 01:01 PM
Sovuf's Avatar
Car: 86 IROC
Engine: Soon 355
Re: 416 heads
Okay, so it would not be a performance-wise decision. What about if I got the old smogger-heads that were on the 350 and had them shaved to up the compression. It has the old 78cc smog heads on it.
Old Feb 6, 2009 | 01:04 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 416 heads
Yes you can use them. They are good heads but like most factory heads will require some work to get good performance out of them. They are used often in some restricted racing classes.
https://www.thirdgen.org/forums/tech...ings-416s.html
http://www.castheads.com/factory_chevy_305.php
Old Feb 6, 2009 | 03:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 416 heads
So, how do you "starve" a 350 with 416 heads? With 1.94" intake valves, they'll flow the same as 350 heads because they have the same ports. (Since these 416's came off his LB9, it's safe to assume he already has an intake to match them.)
416's are a decent head when given the above-mentioned 1.94" intake valves and basic port clean-up. It's generally better from a performance standpoint to control compression ratio with dished pistons than with larger chambers. Therefore, with the same CR and all other things being equal, the 416's can not only hold their own against 350 heads, they are actually better than about 75% of factory 350 heads, Vortecs not included.
Old Feb 6, 2009 | 03:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 416 heads
Link to conversion info to use 8mm LS1 valves - to include the 416 heads.
https://www.thirdgen.org/forums/tech...rings-l98.html
Old Feb 6, 2009 | 05:08 PM
five7kid's Avatar
That would be 76cc, but regardless, that's a waste of money. 416's would run circles around those heads.
Old Feb 6, 2009 | 05:46 PM
Sovuf's Avatar
Car: 86 IROC
Engine: Soon 355
Re: 416 heads
Misread the cc's Thanks for all your help guys! I talked to my buddy who builds race engines and he told me some more information too, so I am sticking with these heads. Thanks!
Old Apr 25, 2009 | 05:53 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: 416 heads
putting aside that they will fit the block and intake, will the other parts, like the alternator, air pump, and the single serpentine belt hook up to later model cars, like my 90 camaro 305?
maybe i should start a link where everyone can list the different head mods and what hooks up and what doesn't?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
