rear main seal
Old Feb 12, 2009 | 08:36 PM
jstringer50's Avatar
Car: 1989 Camaro
Engine: building a 350
Transmission: TH350
Axle/Gears: soon to be 4.10 non posi
rear main seal
I was just wondering if any harm would be done if i applied a small dab of rtv where the seal halves mate (not the bearing cap to block surfaces, the directions state you should apply rtv to the outside of the block recess, but doesnt say anything about the parting lines of the seal-I just worry about leaving it dry and having a leak. please clear this up for me, where should I put RTV, and where should I not
Old Feb 12, 2009 | 11:21 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: rear main seal
It was my understanding that you were supposed to add sealant to the seal halves. I believe my manual told me to use an anaerobic sealant.
Old Feb 13, 2009 | 12:10 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: rear main seal
I always put RTV on the outside and the ends of both halves. I also offset the seams so they are not directly on parting line.
Old Feb 13, 2009 | 10:08 PM
Car: 1989 Camaro
Transmission: TH350
Re: rear main seal
okay, thanks guys,
I put the seal in tonight with some rtv around the outside and a bit on the halves, as well as offset the seal, so fingers crossed it will seal!
Old Feb 13, 2009 | 11:09 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: rear main seal
Interesting...I'll be doing this soon too.
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
