350 or 305
Old Mar 5, 2009 | 08:12 AM
redkaz04's Avatar
350 or 305
Hey guys,
I am looking into buying another third gen...86 IROC with a 5-speed. I am pretty sure the 350 was an option in 86 but regardless the owner claims it is a 350, but how do I tell? It looks a lot like my 85 305. Any help.....
Old Mar 5, 2009 | 08:24 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Re: 350 or 305
first off the 350 came out in 87. Can't come with a 5 speed or T tops. Second a 305 and 350 look identical cause the blocks are the exact same size on the outside and everything can swap between them. You have to get the codes on the motor to tell if its a 350.
Old Mar 5, 2009 | 08:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 350 or 305
Originally Posted by redkaz04
regardless the owner claims it is a 350...
As David mentions. Claiming that a car is equipped with a 350 is like claiming the car is an IROC: Those claims make the car more desirable. Don't bite on this one. Check the following link for more info about the 350:
https://www.thirdgen.org/1987-chevy-camaro
JamesC
Old Mar 5, 2009 | 09:12 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 350 or 305
Yea everone claims there v8 camaro has a 350. In 86 a few prototype 350s bere built but supposedly they were all destroyed. Now its possable that it has a 350 swapped in it but for that you would need to look at casting numbers or suffix codes.
Old Mar 5, 2009 | 10:44 AM
redkaz04's Avatar
Re: 350 or 305
ahh that's right...87 was the first 350. I was very up tto date on my options when I bought my 85 IROC. I know how to check the Vin to tell if it is a iroc.
Old Mar 5, 2009 | 10:46 AM
redkaz04's Avatar
Re: 350 or 305
perhaps the plate on the door says the manufactured date was like september 1986? Wouldnt that make it an 87 actually?
Old Mar 5, 2009 | 10:48 AM
redkaz04's Avatar
Re: 350 or 305
the engine might be swapped into a 305 car before he got it? I guess i will be able to tell when I look at it if I can find the motor codes which are located....where?
Old Mar 5, 2009 | 12:30 PM
Re: 350 or 305
Well you are right the build year and the modle year are different but again if its an 86 modle year then its an 86 reguardless of when it was actually built but thats will be noted in the VIN number. There are 2 numbers you could look for. 1 the suffix code which will be on the passanger side of the motor where the head meets the block or the casting numbers which will be on the back top side of the motor's flange that bolts to the trans. Unfortunetly i dont have and good pictures of locations but you should be able to search online and find some good pictures.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
