Stroke of a different kind!!
Old Mar 8, 2009 | 03:29 PM
tinymay's Avatar
Engine: 5.7 TPI
Installing a higher volume oil pump, I found THESE!!
Running on borrowed time, huh??
Old Mar 8, 2009 | 03:32 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Stroke of a different kind!!
Ouch... Time to start saving.
Old Mar 8, 2009 | 03:40 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
wow... piston skirt?
Old Mar 8, 2009 | 04:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Looks like it.
Old Mar 8, 2009 | 10:18 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Ouch, that's never a good sign.
Old Mar 8, 2009 | 11:22 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Well, it is best to have light pistons right?
Old Mar 8, 2009 | 11:44 PM
84Z28406's Avatar
That's true, less stress on the rods and rod bolts. Less stress transfered to the crank throws... I guess it's good all round. :P
Old Mar 9, 2009 | 03:21 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Ouch!!! Definately piston skirt. I wouldnt run that motor again. (Unless you dont like the block/crank/connecting rods/heads.) Bummer!
Old Mar 9, 2009 | 07:20 AM
tinymay's Avatar
Engine: 5.7 TPI
Poked my head up in the bottom end and scoped it out. Yep, bottom skirts have popped off 5 pistons. Been running like that a while so maybe I have a bit more time to make a plan.
Bottom end has over 100k miles. No telling when it started fragging. Bet it was back when I had some hydro-lock issues. Knew I was not going to be lucky enough to skate past that one so easily.
Gunner242
Dec 25, 2015 04:49 PM
randy210
Oct 15, 2015 03:43 PM
hartsmike
Oct 2, 2015 07:11 AM
dusterbd
Sep 29, 2015 08:40 AM
