problem with daily driver
Old Mar 17, 2009 | 11:38 PM
B.lane 88's Avatar
Car: 1988 Iroc Z
Engine: TPI 305
Axle/Gears: mini spooled 10 bolt 3.73
Hey guys its been several weeks since the problem started and it hasn't stopped or gotten any worse yet. when I'm cursing on the highway around 60 some times the car jerks and I can see the tack go down 2 to 3 hundred RPMs. Its almost like the car starts to down shift and then decides not to. sometimes I can shift from OD to D and back and it will stop the problem but not everytime. So I'm wondering if its the torque converter or maybe the ecu being dumb.
Old Mar 17, 2009 | 11:45 PM
burnrubber9095's Avatar
Re: problem with daily driver
have you ever done a rear end gear change
Old Mar 18, 2009 | 08:04 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The rear gear has nothing to do with it. And if it was downshifting, the rpm would increase. The tach dropping 200-300 rpm is the torque converter locking up like it is supposed to. Your real problem is that it isn't locked up all the time that you're cruising in OD.
Old Mar 18, 2009 | 01:29 PM
B.lane 88's Avatar
Car: 1988 Iroc Z
Engine: TPI 305
Thats what I was thinking, I really hope it last me a while though.
Old Mar 18, 2009 | 02:09 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
would the torque convertor do the same thing sitting at idle?
Old Mar 18, 2009 | 02:18 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
no. What's it doing at idle?
Old Mar 18, 2009 | 06:28 PM
B.lane 88's Avatar
Car: 1988 Iroc Z
Engine: TPI 305
It idles pretty smooth sometimes it acts like it misses every 15 seconds or so and it is also really hard to get into park like the trans cable is not adjusted right.
Old Mar 18, 2009 | 06:32 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I hafta be honest and admit I don't know what's going on with your trouble at idle. Anyone else ?
Old Mar 19, 2009 | 10:42 AM
kcallais's Avatar
Car: 1985 Z28
could be a bad injector causing the miss at idle, as well as a misadjusted gear cable or bad lever assembly on the transmission itself for the hard to put in park issue. ohm your injectors....they should all read 14 to 17 ohms.....any lower and they need replacing.
Glowsock
Jul 24, 2025 03:15 PM
Infested
May 22, 2018 11:56 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
