Where does neg battery cable bolt to?
Old Mar 17, 2009 | 11:52 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Where does the negative battery cable bolt to? 89 IROC L98..
Old Mar 17, 2009 | 11:57 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: Where does neg battery cable bolt to?
your battery and the other side goes to your frame rail.
Old Mar 18, 2009 | 12:26 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
From the battery to the body then if you want add another from the same body location to your engine.
You won't regret it!
Old Mar 18, 2009 | 12:32 AM
Ca[maro]88's Avatar
yeah i put one from the battery cable to the engine behind the a/c compressor bracket.
Old Mar 18, 2009 | 01:16 PM
89RsPower!'s Avatar
Yeah already have it grounded to the rail, couldn't remember if it had a ground on the block or not too, pulled the engine a year ago..
Old Mar 18, 2009 | 03:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The large negative cable goes to the engine block somewhere - varies from model to model, engine to engine, and doesn't really matter. Mine bolts to the alternator bracket. Going directly to the engine makes sense since the starter is the biggest amperage draw of any part of the electrical system (unless you have a mighty big subwolfer amp ).
A small wire goes to the chassis. That's just to make sure you have some ground to the rest of the accessories. My '57 didn't even have that.
Old Mar 18, 2009 | 03:51 PM
50bmgshooter's Avatar
you better make sure that you have a ground from the motor to ground if not your dizzy and alt will try to find a ground.
I have seen throttle cables burn off because of no ground strap.
Old Mar 19, 2009 | 08:30 AM
89RsPower!'s Avatar
Yeah factory ground strap is on, the grounds 2 the back of the heads r on, just wanted to know where on the block the factory put the end of the neg cable, I know it really doesn't matter ground wise, just trying to put everything back as it was. I guess I'll just attach it where ever it reaches to..
Old Mar 19, 2009 | 08:32 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
On my '88 it is connected to the exhaust manifold stud shown below. The manifold is bolted on with the stud and then the P/S brace (removed for clarity) then the ground cable, then the nut.
Old Mar 19, 2009 | 10:13 PM
89RsPower!'s Avatar
That's where I bolted it to, except on the opposite side since my battery is on the other side of the car. That seemed to be the place it most easily reached to so I figured that's probably where it was from the factory. Thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
5spdcamaro
Aug 28, 2015 02:12 AM
Jae992
Aug 27, 2015 09:07 AM
Accerrito22
Aug 23, 2015 07:22 PM
