Increase HP
Car: 1988 Trans Am GTA
Engine: 350 5.7
Increase HP
To start off let me introduce myself! I just joined and my name is Kolby. I recently bought a 1988 Trans Am GTA and I LOVE it. I got to eat my first Honda two days ago and it felt great. Now here is my question. I want to increase the horsepower. What would be something good to start off with? I'm not wanting to spend thousands of dollars. I just want to increase it a bit, keep busy, and have fun. Thanks in andvance!
Car: 1990 iroc-z
Engine: 350 tpi
Axle/Gears: 3.23 posi
Re: Increase HP
well welcome to the party! lol i'd say the first thing to do is a full tune up and then get a cat back with a flowmaster and then build on that with headers then skys the limit from there. afr with bigger injectors and mild port work to the intake. it all depends on how big your wallet is
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Increase HP
Definitely Tune up. As for AFR's? Probably not even close to that mod yet. Try a high flow catted exhaust with some headers.Thats good for bang for the buck. Or Maybe an open element K&N Air filter too.
Engine: 350 5.7
Re: Increase HP
Thanks!
Engine: 350 5.7
Re: Increase HP
Car: 1992 RS 6spd
Car: 1990 iroc-z
Engine: 350 tpi
Re: Increase HP
ive got full exhuast headers hi flow cat and flowmaster and it made a big difference. then i did the ram air mod and wow
made a huge difference but ive only driven it once and it the middle of the drive my hood folded up on me
it sucked hardcore but ive got 24lbs injectors and afr my mechanic is puttin in along with a set of roller rockers. but i just bought an 84 z28 with a turbo daytona hood for 400 that runs and drives so im pumped about my new hood and being able to drive my car again
it sucked hardcore but ive got 24lbs injectors and afr my mechanic is puttin in along with a set of roller rockers. but i just bought an 84 z28 with a turbo daytona hood for 400 that runs and drives so im pumped about my new hood and being able to drive my car again Trending Topics
Engine: 350 5.7
Re: Increase HP
Here is what it has so far.
Elderbrock headers, oversized plentum, MSD ignition, MSD coil, BBK intake, racing thermostat, K&N Ram Air intake.
Car: 1990 iroc-z
Engine: 350 tpi
Re: Increase HP
did the car already have this stuff when you bought it or did you do it? cause you may already have some sort of a system if the headers are already on the car
Engine: 350 5.7
Re: Increase HP
It was done when I bought it. I'm going to go and look under my it now to see what it has. Thats if I can fit under it.
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: Increase HP
lol just like my car. Had a pyro kit in it, fun to play with but really bad on mpg. My vote is have a mechanic carefully go through it and tell you exactly what you have, it will make future upgrades/mods much more straightforward and lower the number of surprises you will encounter. Just my experiance.
Elephantismo
Feb 13, 2019 12:51 AM
WhteRbt
Sep 21, 2015 09:48 AM
