350 rebuild
Old Mar 22, 2009 | 06:53 PM
Markemery's Avatar
Car: 96 z28, 94 concorde,
Engine: LT1 and a 400SB in thoe works.
350 rebuild
Hey guys ....im sure u get alot of this but im having trouble finding some decent info on what i should do.
I recently picked up a 350 ..i looked up the serial # and it came from a 69 to 79 corvette not sure which year tho it was in a friends garage for years (2 bolt main)
Anyway i am thinking going 383....me and a buddie did some playing around with a engine program and managed to come up with 460 hp and 480 ftlbs
with 10.5 to 1 compression..these are the parts that we used to get the numbers i just wanna know what some of u much more experenced people think..Will this work ...do i need to worry about blowing this engine up ...i am also planning on replacing the transmission with a Tko 500...anyway please let me know what u guys think Be as crititcal as possible ... iknow the cam is rogh idle and i may end up changing that out ...anyways i will apprecate any info thanks!
Last edited by Markemery; Mar 25, 2009 at 11:31 AM. Reason: wrong info(part numbers are wrong)
Old Mar 22, 2009 | 07:06 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 rebuild
Your buddy is stuck in the stone ages, with those outdated heads and cam. You can do much better. For the same money. Heads: The sportsman 2s were good in the late '80s, before we had any good choices, but these days, the bang-for-the-buck in iron heads is either RHS -Racing Head Service, or EQ -EngineQuest. Better short-turn, better combustion chambers. The tech in that cam is even older. Step up to something like COMP CAMS' Thumpr or Extreme Energy lines. An XE274 will far surpass that old Torker grind. Top with an Edelbrock RPM AirGap intake and a Holley 770-cfm carb. 480+ horses, no problem.
Old Mar 23, 2009 | 12:24 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
Re: 350 rebuild
I recently picked up a 350 ..i looked up the serial # and it came from a 69 to 79 corvette not sure which year tho it was in a friends garage for years (single bolt main)
World Castings Sportsman II Heads p/n: 012250-1
Edelbrock Torker Plus Camshaft & Lifters p/n: 5002
Holley 650CFM Double Pumper Carb p/n: 0-4777C
SCAT Rotating Assembly p/n: 1-90355
just for the record what you have is a 2 bolt main. 350's came in 2 bolt and 4 bolt main variates. 2 bolt mains have 1 bolt one each side of the crankshaft. a 4 bolt setup has 2 bolts on each side of the crankshaft. there is no such thing as a 1 bolt engine
Old Mar 23, 2009 | 12:32 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: 350 rebuild
my car went 10.8 on motor with a 10.6:1 383 with edelbrock heads, vic jr, and 230* roller cam.
i have the heads and intake fs. they wil make for a strong 383
Old Mar 23, 2009 | 05:45 PM
Markemery's Avatar
Re: 350 rebuild
good to know .....my bad
Old Mar 23, 2009 | 05:46 PM
Markemery's Avatar
Re: 350 rebuild
really eh ... i im intersed in that setup im in Canada tho ill have to look up what shipping is and exchange ...umm any way can i get a hold of u to possibly talk about this ?
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
