Roller rockers.....NSA or self aligning?
Old Mar 26, 2009 | 07:55 PM
kcallais's Avatar
Car: 1985 Z28
Axle/Gears: garbage 2.73
Does it make a huge difference between NSA and SA? Wondering what was better for a 305 tpi.
Old Mar 26, 2009 | 09:19 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: Roller rockers.....NSA or self aligning?
There isnt really a distinct advantage to either system, you will need to purchase rockers that are compatible with your heads. More than likely, unless you have aluminum L98 heads or aftermarket heads with screw in studs, you need self-aligning rockers.
-Zander
Old Mar 26, 2009 | 10:18 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Self adjusting rockers are required on heads that don't have built in pushrod guides.
Old Mar 27, 2009 | 12:33 PM
kcallais's Avatar
Car: 1985 Z28
Would this work? http://www.jegs.com/i/Comp+Cams/249/1418-16/10002/-1 Looking for a relatively inexpensive set of 1.6 rockers.
Old Mar 27, 2009 | 12:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yep.
$200 though?
That's hardly budget. I have 1.6 SA rockers that were about $120. Roller tipped.
If you don't have HEFTY springs you won't need those ones.
I think mine are from CNC motorsports...
Old Mar 27, 2009 | 12:59 PM
kcallais's Avatar
Car: 1985 Z28
Found these.... http://www.cnc-motorsports.com/produ...06&CtgID=14967
Old Mar 27, 2009 | 02:15 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I bought a set from CNC motorsports once. I liked the rockers but the lock nuts didnt seem right. They felt way too tight. I ended up using a new stock replacement nuts and discarded the ones that came with the rockers.
Old Mar 27, 2009 | 03:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Those are exactly the ones I have. Even cheaper than I remember.
Those work just fine.
I used poly locks instead, as I have a solid flat tappet cam.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
meeklay812
Oct 1, 2015 03:46 PM
