no injector pulse on 89 firebird!HELP!
Hi everybody. I bought an 89 firebird project. It had the 305 swapped out for the 350 maf when I got it. Had the battery moved to the rear and a bad starter. Put a new starter in it got it to crank. Found a plug wire off cylinder one. Fixed it. Cranked it over. No fuel pressure at the regulator. No power to the fuel pump relay. The pump fuse has power at the fuse box. I hotwired the pump to the battery and the pump ran. I cranked the car and it won't start because the injectors aren't pulsing. The car has a "165" ecm in it and a hypertech prom ( supposedly a 350 chip). The injectors have power on both terminals of the individual injector connector. Also, the check engine light doesn't come on when cranking. I disconnected the tpi and maf sensors and turned the key on and the light didn't come on then either. Is this normal? I pulled the check engine light bulb from the cluster and it is a good bulb. I'm thinking I have a bad ecm. Also, I know the vats disables the starter, but is there any way it could disable fuel injector pulse on an 89? I also read a thread that there is a connector near the ecm for the injectors that you have to connect to hot when a 350tpi is put in a tbi car. Is this true? I'm pulling my hair out. Any help at all would be greatly appreciated. ( almost forgot. I shorted the diagnostic terminals on the aldl conn. and the check engine light DID NOT come on then either) thanks everybody
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: no injector pulse on 89 firebird!HELP!
Originally Posted by firebirdturd
I cranked the car and it won't start because the injectors aren't pulsing. The car has a "165" ecm in it and a hypertech prom ( supposedly a 350 chip). The injectors have power on both terminals of the individual injector connector....
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
You said you moved the battery so I'm not sure where you will find it, but there is a 20 amp fuse on an orange wire that should be connected to the positive battery cable. The stock location for the fuse is on the drivers side radiator support,near the top, it supplies power to the ecm, the fuel pump, and a few other things I can't remember right now. Sounds like the fuse is blown or some how disconnected.
Also, I know the vats disables the starter, but is there any way it could disable fuel injector pulse....
If it was a vats issue the security light would be lit plus it would reset itself after about 5 minutes
Car: 1985 Z28
Axle/Gears: garbage 2.73
The injector pulse will be disabled by VATS. The ignition is only disabled if there is a VATS module installed on the driver side kick panel. If you turn your key on, and there is no check engine light, you have either a bad prom, ecm, or wiring. If you have a friend with a third gen, borrow their ecm. Or you could spring the 90$ to get a remanned one from autozone.
Hey everybody, thanks for the response. I know the battery is in the trunk. I was just providing some info about the car. I know the injectors aren't pulsing because I unplugged them and put a noid light across them. Then I had a friend crank it while I watched the light. No light. The security light does come on when you first key up the car. So I know the light is good. But it does not stay on while cranking. I will definitely look for the fuse that powers the ecm, injectors and fuel pump. I'm just hoping that whoever butchered this car didn't mess that up either. I'll let you guys know what I find. Thanks again.
No ses light could mean no power to ecm, you stated that you relocated your battery, did you properly extend and reconnect all the wires that came off the battery cables, the orange wire off the pos+ battery cable supplies power directly the the ecm and the fuel pump relay.
Car: 1985 Z28
Also, you could try checking the 3 fusible links on the starter. I'm pretty sure one of those sends has power routed to the ECM through it. Will be a red colored tube on an orange wire.
I know the injectors aren't pulsing because I unplugged them and put a noid light across them. Then I had a friend crank it while I watched the light. No light....
So I got the firebird to run! It was that wire coming off the pos. batt cable had a break in it. Thanks so much john 89 formula! You pretty much hit the nail right on the head and sent me right to the problem. I want to also thank everybody else who posted for the good ideas. I took the car out for a spin and it has some good power to it. The idle is a little loopy, but that might be because the previous owner put a cam in it. (There's no check engine light when running. ) This site rocks and you guys are great!
No problem. I had to repair that wire on 2 of my cars. It was the first thing that came to mind when I read your post.
New2Chevy
Oct 4, 2015 11:27 PM
