89 305 TBI installing mechanical oil pressure gauge need help
Old Apr 8, 2009 | 04:44 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ok so i searched and searched through different threads on the oil pressure switch and im honestly confused now. From what ive gathered there are 3 different oil pressure setups GM used throughout the years. #1 is just the bell style up by the intake, #2 was a combo of that bell and then the one above the oil pan and then in the 90's they came out with #3 which was just the block mounted one above the oil pan correct?
Im trying to install a mechanical o/p gauge on my 305 TBI. I dont know where to put it, if i pull the one from the block (which is the only one i saw) then i risk losing my fuel pump because the oil pressure switch wont allow the injectors to fire until it sense pressure
im posting up 2 pics, i need a legit opinion on this im thinking i can just get a t block, put it into the pan where the switch is (assuming thats the style) and run the stock switch on one side and the mechanical gauge off the other side
thie pix are kinda bad, i circled the switch above the pan though, its there lol
Help would be greatly appreciated
Old Apr 9, 2009 | 12:13 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 89 305 TBI installing mechanical oil pressure gauge need help
BUMP Anyone able to help?
Old Apr 9, 2009 | 12:15 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
I guess you don't have the one off the block behind the intake. Does your switch above the oil filter have 3 wires? If so, it's built into that. If that's the case, I have something here you can have to mount your new gauge sending unit. Call me and we'll get that to you ASAP.
Old Apr 9, 2009 | 03:22 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
alright ill take a look at it tomorrow, im thinking its 3 wires but i havent taken a good look at it for a few weeks.
btw installed the blue 5 LED bulbs from superbrightleds and im really lovin them, they glow like an ice blue at night
Old Apr 9, 2009 | 04:33 AM
Icarus 402001's Avatar
Car: 92RS
Picture?
Old Apr 9, 2009 | 04:08 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
*Chris* i pulled the connector and it turns out it is the 3 pin deal.... the thing that confuses me is why its on my 89 i thought that was a 90-92 deal?
Originally Posted by Icarus 402001
Picture?
well my phone is terrible for night pics so the blue looks retardedly bright but here it is:
I like them personally, plus it matches my stereo and the overall goal for the car (fan of blue) you can see the difference between the superbright ones and then the dash are the ones i did myself, im gonna swap them out for the new ones once i order more, i also like the fact that ill be able to dim them lol
Old Apr 9, 2009 | 08:44 PM
birdtojag's Avatar
They combined the pressure sender and switch in the same component in 89. I have a way to get your new gauge to work without having to pull that component out.
Old Apr 9, 2009 | 11:12 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
you can run a tee block at one of the switches. done that several times without a problem.
Old Apr 10, 2009 | 03:37 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
the only switch is that on off the block, ill just swing by chris's place and we'll test his idea, normalyy theyre pretty good lol
Old Apr 11, 2009 | 10:50 AM
birdtojag's Avatar
We are going to try putting a tee block in the port behind the intake. We just have to remove a plug and put the block in. I have a single port tee block that came from an older T/A. We will get this done so the gauge works.
Old Apr 12, 2009 | 02:43 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
just checked the fittings, ive got and they all match up (for once no problems) so tuesday ill head out to my parents place in QC and set it up since i cant even open my hood without my apartment managers comin by to nail me with a million questions as to why im working on my car lol
Old Apr 12, 2009 | 06:11 PM
birdtojag's Avatar
SWEET!
pimp2303
Jul 27, 2017 02:03 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
92purpz28
Aug 11, 2015 02:30 PM
