<<Vortec engine questions....>>
Old Apr 21, 2009 | 12:24 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Ok, did a search and there was too much info!!
I have a simple question: What are the differences between the 97 Chevy truck Vortec engines and the L98 engines? i know the heads are different and will require a new Base to use my TPI stuff and I know the serpentine brackets will not work, but is everything else in the right place?
Thanks!!!
Old Apr 21, 2009 | 01:02 AM
Re: <<Vortec engine questions....>>
I suppose I should clarify a few things: The car I am thinking of putting it in is an '86 IROC, and the engine in question is a 350 Vortec from a 97 Chevy tahoe.
Old Apr 21, 2009 | 03:02 PM
Er... Anyone?
Old Apr 21, 2009 | 03:18 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
yea everythings the same... i have a vortec350 in my 83 ta and all the stock brackets bolt right up
Old Apr 21, 2009 | 03:22 PM
Good deal!! I am right, that I will need a new base to use my TPI, right?
Old Apr 21, 2009 | 09:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, and the vortec TPI base is a pricey piece...
Old Apr 21, 2009 | 09:59 PM
How pricy, and where do I find it? I have been looking and havent found it.
Old Apr 22, 2009 | 12:13 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Summit Racing or Jegs will have it. Edelbrock makes them. Usually about $470 or so.
Old Apr 22, 2009 | 12:28 AM
Ah, Thats not too bad.
Old Apr 22, 2009 | 06:44 PM
Ok, I guess I will modify this a bit and ask: Who makes TPI bases for vortec heads and which is the best one?
Old Apr 25, 2009 | 01:55 AM
And what about a roller cam? Something kind of radical, but still streetable.
Old Apr 30, 2009 | 03:57 AM
Ok, the only thing I am missing is the cam... I want to stay with a lift the stock heads will handle without any machine work. (I'm not opposed to changing the springs, though.)
Thanks!
Old Apr 30, 2009 | 09:33 AM
90Formula305's Avatar
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
I'm thinking about doing this but just using the stock vortec stuff. My car is a TBI though so I don't have anything worthwhile to swap over.
Old Apr 30, 2009 | 03:21 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Check out the thread I just posted. Im running a 97 vortec motor in my 88. I just installed a LT4 Hotcam. I was able to do get by with the lift problems without pulling the heads. I love that cam. I however am running a carb, so you will have to retune your computer for the new cam.
If you want to keep with the TPI, go with the Edelbrock IMO
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
