failed cali smog test
Old Apr 22, 2009 | 12:56 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
but the only problem i had was that my NOx was a little high on the 25mph test, the max allowable was 706 and I measured 755, what should i check out to fix it, I think it might be my timing because its set at 6 degrees BTDC
Old Apr 22, 2009 | 02:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: failed cali smog test
Please post all the other measurements and max allowable for both 15MPH and 25MPH.
Old Apr 22, 2009 | 03:19 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
first off id like to include that my gas cap was bad, now here are the results
15mph test at 1580 rpm:
CO2 meas. 13.50
O2 meas. 1.74
HC Max-108 Meas.-48
CO% Max-.71 meas.-.13
NO(PPM) Max-767 meas.-755
25mph te st at 1508 rpm:
Co2 meas. 13.43
O2 meas. 1.93
Hc Max-83 meas.-28
CO Max-.58 meas.-0.10
NO(PPM) Max 706 meas.-775
Old Apr 22, 2009 | 06:26 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
any help would be great...
Old Apr 22, 2009 | 06:44 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
EGR valve is not working as well as it should. Replace it, and clean out all the EGR passages.
Old Apr 22, 2009 | 09:43 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Forgot to ask....what kind of engine is in your car? Carb? TBI? TPI?
Old Apr 22, 2009 | 11:42 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
its a tpi
Old Apr 23, 2009 | 11:33 AM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
also my car was staling on the dyno a lot, but i think it because ive been havin this issue with my car stalling when you first start it up and put it in reverse or drive, so you have to keep the rpms up to get going, then after you have been driving it awhile its fine and doesnt stall, but this doesnt happen when its cold so i have no idea whats causing this I think its either a vacuum leak,the IAC valve isnt working or something with the transmission
Old Apr 23, 2009 | 02:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
From your test numbers, I'm going to say it's either mixture (lean) or your EGR system.
You can't tell from the test numbers if you're running lean because the AIR pump is pumping air into the catalytic converter so there will be a reading of excess of O2. If you have access to a scan tool you can check the mixture my monitoring the Integrator values. There is a way to monitor the O2 sensor without a scan tool, but I don't have the procedure handy.
For checking the EGR valve, you cannot just hook up vacuum to it while the engine is running to see if it stalls. The EGR vlave is a negative back pressure type valve. It should hold vacuum when the engine isn't running, but as soon as it sees exhaust pressure it will close. However, doing this test will tell you if the EGR passages in the lower manifold are clear.
There is a flow chart in the FSM that describes how to check the EGR system (it's not the same chart for a Code 32). If you don't have a FSM, I will try to scan and post the flow chart.
In the mean time, check for any vacuum leaks. vacuum leaks can cause the mixture to run lean.
Old Apr 23, 2009 | 02:44 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
i think i actually have my timing set wrong i think its actually set a 6 degrees after top dead center because its set at the first notch on the left of the 0
Old Apr 23, 2009 | 02:49 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Timing marks to the left (anti-clockwise) of the "zero" mark is before TDC.
Old Apr 23, 2009 | 05:04 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
alright thanks for clearing that up for me, i did the timing myself and i wasnt entirel sure i had it right
Old Apr 23, 2009 | 05:07 PM
Guest
Guest
Posts: n/a
They should have noticed if they actually checked it right, but did you disconnect the EST when you set the timing? If not its about 15 or so degrees off and may explain the stalling if nothing else.
Old Apr 23, 2009 | 06:13 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
yes i did disconnect the EST but they werent able to check the timing because the car was stalling, that was another reason why I failed
Old Apr 23, 2009 | 10:15 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Attached are the pages from the FSM describing how to check the EGR system when no Code 32 is set. Sorry about the scan quality. It's the best I can do considering the thickness of the book and the flatbed scanner.
Good luck.
File Type: pdf
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 10, 2015 09:39 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
reactor60
Sep 22, 2015 01:44 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
