power problem please i need all the help i can get
Old Apr 25, 2009 | 12:28 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
iv done a serch and cant find what im looking for there so here goes i have an 87 tpi rebuilt 40 over flat tops new 21 pound venom injectors factory cam with 1.6 roller rockers adjustable fpr headers port matched runners to intake and plenum and intake to heads.I had one bad head so i had to get a set that came off a ton truck they had some kind of swirl guide lookin thing in the intake valve chamber never saw that b4 but i didnt replace my roller lifters and they came out in 87 along with the cam and they bleed all the oil of over night and in the morning b4 i start it i can push the plugers down by hand very easy.After i start it and they pump up and the noise goes away for the rest of the day but could i be loseing lift and power there or will the oil pressure be enough to open the valve right?also the springs are from 87 to i put the ones from my heads on the ones i bought should i replace them because it just dont have the power it did when i got it.It was about 5 or 7 years old then and it would peg the speedo and keep going.i think it should have even a little more now than then with the 40 over bore and the 1.6 and other mods i mention.im going to put on some aluminum heads and probly a bigger cam in a year or so and was wondering what would be the best heads and cam for what i already had.please help im spending money after money with no results and getting disappointed badly i know its there thats keeping me going but i just cant find it.could an old egr cause power loss
Old Apr 26, 2009 | 12:26 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: power problem please i need all the help i can get
The swirl port heads are the problem. Far more of a problem than you would ever imagine. Make heads, with good springs, the very next thing you do. Of course, it's easiest to do a cam when the intake is already off for the head swap, But you need to pick heads before cam.
Old Apr 26, 2009 | 01:01 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The Swirl Port heads ARE NOT the problem.. Sorry...They are a GREAT match for the stock cam, base, and intake runners. Its the lack Tuning. The original poster needs to make sure his timing is set properly. The fuel pressure is within specification. The TV Cable is set correctly on the transmission.
Old Apr 26, 2009 | 09:24 AM
Car: 87 iroc z
Engine: 358 tpi
tv cable adjusted as said on tech page here fuel pessure is at 45 idel with no vacume and timeing is set to max with no grunting when hot starting and no knocking all the tuning is right on iv played with it for a while maybe it maxed out and i just dont know it but i should be able to go 145mph but cant?
Old Apr 26, 2009 | 10:49 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Not so. I've driven a GTA that had the usual bolt-ons, swirl-port heads, and the stock PROM. I drove it again after switching to ProTopline 180 heads, no other changes. And I had both sets of heads on a new SuperFlow 1020 flow bench. Think about it. If the heads weren't the problem, there's no way the PROM that used to get him over 145 mpg would now be keeping him from it.
Old Apr 26, 2009 | 11:37 AM
Car: 87 iroc z
Engine: 358 tpi
this has been comeing on slowly first it was maxed at like 120 then 110 then 100 and so on thats when i rebuilt messed up one head thats the only reson i even changed them but it seems like the rebuild made not much of a diff when i added the injectors they got my torque back just no top end
Old Apr 26, 2009 | 12:23 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
This can be explained by the lack of airflow due to the heads, plus plenty of fuel from the injectors ( which solved your lean misfire in the midrange ) and it's going rich up top, which definitely hurts power.
Old Apr 26, 2009 | 12:49 PM
Car: 87 iroc z
Engine: 358 tpi
so if i get the heads i need which will probly be a set of jegs aluminum or some kind of edelbrock alum i should be back in the ball game and run 145 and smoke the tires and whatever i want.what kind of heads would you recomend i want something that would be good for a fairly big cam but ill probly keep my maf becaus of it being more forgiving about big cams.
jhawkeye
May 25, 2022 06:33 PM
355tpipickup
Aug 27, 2015 08:13 AM
neekolzun
Aug 24, 2015 04:59 PM
Bert87
Aug 23, 2015 03:50 PM
db057
Aug 22, 2015 08:17 PM
