engine misses when first started
Old May 5, 2009 | 11:35 AM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
I have a 86 iroc 355 w/ carb, edelbrock rpm performer intake, fuelie heads, comp cams extreme enegy cam. when i start the car for the first time of the day, it is running on only 6 or 7 cylinders. it will do this all day, the only way i can get it to clear up is to floor it for about 6-8 seconds. it will run perfect the rest of the day. im thinking the plugs get something on them causing them not to fire until i floor it. if i change them, the car doesnt miss when i start it until a few days later. i first thought the carb, but i swapped carbs, still does it. have good fuel pressure. any suggestion are greatly appreciated.
Old May 5, 2009 | 11:38 AM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
Re: engine misses when first started
Is there any black smoke when you "floor it"?
Old May 5, 2009 | 11:44 AM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
i dont think there is, i have turn downs on the mufflers.
i dont notice any black smoke
Old May 5, 2009 | 11:51 AM
How many miles on the engine? What is your oil pressure?
Old May 5, 2009 | 12:01 PM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
i would take the plugs out and take a air gun and shoot out all the spots where the plugs were you might have like little tiny leave peices in there which can be doing that also check your rotor dist and plug wires
Old May 5, 2009 | 12:12 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
there is about 4000 miles on the rebuilt engine. i dont know how many the heads have on them or how new the parts on the heads are. the cam and intake were new when i put them on. the oil pressure is good, 20 at idle 40-60 while driving
Old May 5, 2009 | 12:22 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
have brand new mallory hei distributor and new msd plug wires
Old May 5, 2009 | 12:43 PM
I am wondering about the lifters.
If the heads have really strong springs, it can cause the lifters to bleed off while sitting over night and keep them from pumping up at an idle.
Just a thought...
Old May 5, 2009 | 12:56 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
your actually the second person to tell me that. the guy i got the heads from said the springs are good to .550, but who knows if he really knew or not. ill have to see if i can find a part number
Old May 5, 2009 | 01:11 PM
Any info on the lifters you used?
Old May 6, 2009 | 02:35 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
i realized when i change the spark plugs, the engine doesnt miss when i start it until after a few days. then i have to start flooring it again to make it run right.
Old May 6, 2009 | 03:40 PM
Car: 91 Camaro
sounds like stuff between your spark plugs and the engine
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
