choke light
Old May 10, 2009 | 03:30 PM
AKATDOG's Avatar
Car: 84 Z28
choke light
for some reason when i start my car no matter hot or cold the choke light inside flashes and makes an anoying ticking sound, anyone know what the problem could be ? its a q jet carb with electric choke...
Old May 10, 2009 | 09:01 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: choke light
The clicking is normal for the CC Qjet. IIRC, thats the MCS going through its self-check cycle. Something like that anyway. Mine did that as well.
Old May 10, 2009 | 09:55 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: choke light
So you mean the ticking is coming from the engine and not the light flashing, correct? The ticking sound is the Fuel Mixture Solenoid in your Qjet. If you turn the ignition to "On" the ticking starts and lasts for several minutes. Why your light blinks is a mystery to me. Take off your air cleaner and see if the wire is hooked to the choke. There should be a constant voltage to the choke. You can take a test light and with the ignition to "on" check and see if your getting voltage.
Old May 10, 2009 | 09:56 PM
AKATDOG's Avatar
Car: 84 Z28
Re: choke light
no but it wont stop, the choke light keeps flashing, and everytime the lights comes on it makes a click, but the light is what the problem is, why does it keep flashing ?
Old May 10, 2009 | 09:57 PM
AKATDOG's Avatar
Car: 84 Z28
Re: choke light
thanks i will double check the connection
Old May 12, 2009 | 09:25 AM
AKATDOG's Avatar
Car: 84 Z28
Re: choke light
ok the connection at the choke seems fine but with the key on theres only .8 volts there, does the car have to be running to check it ?
Old May 12, 2009 | 10:48 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: choke light
So where's it ticking then? And how fast? And how fast is the light blinking?
Yes, the choke is not supposed to be heated until the engine is running.
Old May 12, 2009 | 10:55 AM
AKATDOG's Avatar
Car: 84 Z28
Re: choke light
the ticking is coming from the dash it seems behind the light, the light flashes fast (a few times a second) and sometimes slower (one time a second) and very faint can only see it at night, i checked voltage with the car on and its just below 14 volts...
Old May 12, 2009 | 11:43 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: choke light
Choke relay is behind the dash.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
