PLZ HELP FAST!!!!!
Old May 13, 2009 | 01:46 AM
buttroq's Avatar
PLZ HELP FAST!!!!!
need to find out if my engine is roller or not. 1986 trans am 305 tpi automatic, is there a way to tell before i tear it apart to replace timing chain set up??
Old May 13, 2009 | 02:10 AM
Prickly's Avatar
Car: 88 Formula
Engine: E code, what else is there ??
Transmission: 700R4 stock
Axle/Gears: Stock w/ limited slip
Re: PLZ HELP FAST!!!!!
Call a parts counter and ask for the camshaft or replacement engine description for a fast answer if the engine is the original that came in the car.
Old May 13, 2009 | 03:03 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
If your engine is original, it is not. GM started using roller motors in these cars in 87.
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
if you are stock you cam is probably hydraulic flat tappet. they were stock up to 1986 and were limited to about 6500 rpm. from 1987 up they were hydraulic roller. but everything depends on the year of the engine. if you are sure it is stock then it is hydraulic. you can pull the intake and look into the valley - if there is a spider in the valley over the roller it is roller and if not it is flat tappet.
Old May 13, 2009 | 11:35 AM
buttroq's Avatar
thx guys. i know how to identify them with the intake off, just didnt want to go that route to replace the timing chain, as far as i know its the original engine. just was wondering if there was a way to tell before i get parts and end up with the wrong ones.. good info to know though, thx again..
Old May 16, 2009 | 11:48 PM
buttroq's Avatar
thx for the input, it is flat tappet, thx again
Old May 18, 2009 | 09:23 AM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
Look on the pass side front of the engine block on front of the head where your alternator is and theres a set of numbers. Write them dowm and cross reference them on nastyz28.com and it will tell you everything you need to know about your engine.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
