Turn signals wont work
Old May 16, 2009 | 04:50 PM
Rduffy123's Avatar
Car: 1985 Camaro IROCZ
Engine: 305 V8 TPI
Axle/Gears: 3.42 gears
Turn signals wont work but the hazards do. Checked fuses and all are fine. What should I check or fix to get my turn signals to work again, I have a new flasher unit but I dont know where it goes. Any help guys?
Old May 16, 2009 | 05:21 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Turn signals wont work
under the dash by the drivers feet, near the fuse box. take the lid off you should see it.
good luck
Old May 16, 2009 | 07:50 PM
Rduffy123's Avatar
Engine: 305 V8 TPI
looked under there aqnd couldnt tell where it goes, anywhere with a picture of it?
Old May 18, 2009 | 02:20 AM
Rduffy123's Avatar
Engine: 305 V8 TPI
Any help here guys? I cant find the thing and my searches arnt finding anything.
Old May 19, 2009 | 12:53 AM
Rduffy123's Avatar
Engine: 305 V8 TPI
bump
Old May 29, 2009 | 12:30 AM
Rduffy123's Avatar
Engine: 305 V8 TPI
no one can tell me where the flasher unit is on my car? My chilton is in the mail so I need to know fast, without signals driving around town is harder.
Old May 29, 2009 | 03:04 AM
Klewis89RS's Avatar
Car: 86 IROC, 90 F-250
Engine: LB9, 460
Transmission: 700R4, C6
I have the same problem! someone help!
Old May 29, 2009 | 03:45 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
whenever my signals go bad, i usually have an Irish Midget direct traffic for me. haha. but seriously, if your bulbs arnt bad, and the fuse isnt bad, then you relay is bad. if when you turn on the signals, do you hear a clicking sound. if not then its your relay. its really not hard. its under the dash i stink
Old May 30, 2009 | 10:51 AM
mreld3r's Avatar
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
I have the same problem, and here is what i was told.
The hazards and the turn signals have different flashers.
Hazard flashers are in the convienience center, which is under the dash behind the ALDL connector (where the buzzer is).
The turn signal flasher is on the other side of the dash, close to the fuze-bocks...
You can troubleshoot this by: replacing the hazard flasher with the turn signal flasher. Swap them.
good luck.
Upon further review, the chiltons book is of NO use. It says that on an 82-84 camaro the flasher is in the convieneince center right next to the hazard flasher. Well that is nice. But on the next page it says that 84-89 it is not. Only the hazard flasher. The turn signal flasher is somewhere else. But it never says where.
SO; I crawled my fat-*** under the dash and I cant find it. I pulled down the fuze box, and all i found was a million scattered completely random mess of wires.
Damn; these cars are low to the ground, i had to lay in the dirt with my head under the dash. I didnt take a flashlight, its dark under there.
Who wired this thing anyway, what a mess. No ties or anything,,,just pushed the wires into a wad and stick a cover over it.
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
