What head gasket to use?
Old May 16, 2009 | 09:58 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I have to rebiuld a Chevy engine. The block has cracked due to freezing over last Winter (I think). I have completely disassembled the engine. I plan on purchasing the ZZ4 block (P/N NAL-10105123) and reuse as much of the original engine as possible.
The ZZ4 is an iron block as well as the cylinder heads (GM 14096217). The old cyl head gaskets are all metal (SS I think). They measure bore 4.125" and the gauge is 0.015" to 0.020". I have always used the Felpro 1010 head gaskets, but that was for an iron block and aluminum heads.
What is my best choice for the ZZ4 block and these iron heads?
Old May 16, 2009 | 10:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: What head gasket to use?
1010's would work just fine.
Old May 16, 2009 | 10:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The Felpro composite gaskets will work fine. If you want to bump the compression slightly, a factory style metal shim head gasket will work.
They're expensive but they'll be the last head gasket you'll ever buy because they're reusable. Get some Cometic head gaskets or Felpro MLS gaskets.
Old May 16, 2009 | 11:42 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
149.00 a set for gaskets is very high. and fel-pro is 40.00 each. that is some money - but well spent.
Old May 17, 2009 | 12:34 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you for the responses. Yea, I think $40 a piece is plenty pricy for me and this particular motor.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
