Anybody Have Dyno results for this Motor
Old May 20, 2009 | 12:38 PM
1983Zsled's Avatar
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
I have built a 350 for my Camaro and I haven't had it dyno'd but I'm sure some of you out there have the same motor and have dyno or quarter mile results. Here's what I running,
1974 Chev 350, .030 over, 2 bolt main, stock crank, connecting rods, ZH 345Np speed pro pistons, 906 vortec heads with the exhaust seat, intake and exhaust cleaned up mildly, and intake port matched, high volume oil pump, double roller chain, Summit K1103 Cam Int. 442 at valve, Exh 465 at Valve, 1.5 stock rockers, edelbrock 2116 intake, Quadrajet carb, redone to handle 350 hp...Heddman 1 5/8 headers, and y pipe, 3" high flow cat back, with a ravin muffler. I usually run 94 sunoco.
Stock 91 700r4, with stock converter, and 3;23 limited slip rear end.
I have used Performance Trends engine analyser and got some crazy numbers, 377 hp at 6000 rpm, and 381 trq at 4500 rpm. Not that I'd run it at 6000 rpm for very long if ever.
Any numbers on combo's close to this would be great !
At the flywheel, or at the rear wheels ...........
Old May 20, 2009 | 01:42 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Anybody Have Dyno results for this Motor
While you should switch to 1.6:1 rockers, your combo sounds fine. I have no trouble believing 377 crankshaft hp, uncorrected, but it's gonna happen around 5500 rpm. And you should be over 400 ft-lbs, from 3500 to 4000 rpm. And before anyone else points it out, this combo is very similar to the 330 hp 350 crate engine from GM, but this one is over 10:1. And with a 700r-4, you'll find better dragstrip results if you do hold first to 6000. I see no reason your combo would be unhappy doing so.
Old May 20, 2009 | 07:23 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Allmost the same as my set up except cam. My cam is Erson .458 lift 284 duration made 375 HP at 5800 and 420ftlbs tq. on engine dyno.
1979 2bolt block, 30 over 2256F speed pro pistons, 12558062 vortec heads, Performer RPM intake, and 750 Holley carb.
Old May 20, 2009 | 09:11 PM
skinny z's Avatar
Last years model was as my sig except I ran a hydraulic flat tappet .458"/218* and terrible shorty headers.
Low 13's at 104 after the upgrade to 1.6 rockers. Terrible 60' at 1.95.
Various on line horsepower calculators guess that to be 375 chp although I thought that was ambitious.
This years roller cam version is high 12's still with terrible 60's at 1.8.
Old May 21, 2009 | 07:23 AM
1983Zsled's Avatar
Car: 1983 Z28
Am I going to gain all that much by going to 1.6 rockers? I know it will be like dropping in a bigger cam, but when I change the ratio in the Perf. trends calculator it doesn't make that big of a difference and it seems to hurt the low end. I didn't want my stock tranny to go POP either. Over the next winter I'm having the 700r4 built for the street, so maybe I'll do the 1.6 rocker arm upgrade then. Which self aligning rockers would you guys recommend?
Old May 21, 2009 | 08:10 AM
skinny z's Avatar
To me it was worth 2/10's. However that was a different day (same track).
Old May 21, 2009 | 08:40 AM
Heslekrants's Avatar
Car: 1990 Camaro RS
Engine: 5.7L Vortec TBI
Transmission: Built 700R4 2800 stall
The 1.6 rockers are well worth it but you will have to do the ".550 lift mod " to your Vortec heads as your lift will jump to .496.
I'm running 1.6 rockers on a Vortec 350 right now.
Old May 21, 2009 | 09:50 AM
1983Zsled's Avatar
Car: 1983 Z28
When I had the heads done they machined them to .550 clearance so I should be OK. Do you use self aligning rocker rollers, or standard 1.6 self aligning?
Which brand is good?
Old May 23, 2009 | 07:53 AM
skinny z's Avatar
I went with screw in studs and guide plates when I went for the 1.6 ratio rocker (non self aligning) upgrade. You can't go wrong with Comp Cams Pro Magnum.
I also had the push rod holes clearenced so there would be no binding isssues.
Old May 23, 2009 | 09:35 AM
1983Zsled's Avatar
Car: 1983 Z28
Looks like I've got a project for over next winter.
1992rs/ss
Jan 31, 2025 05:10 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
