running twin resonators directly off headers as a dump.
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
what exhaust parts are needed to run a single resonator directly off each header and run it out the sides. this is on a drag car and i want to get rid of the y pipe. i also have a three bolt flange coming off of the headers so help would be great if anyone has done it.
Transmission: 4L80E/4L80E
Myspace is filtered by my ISP. What headers do you have?
Re: running twin resonators directly off headers as a dump.
anybody know or have any ideas? they have a 3 bolt flange on the bottom of the header.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Pictures would help.
My headers don't have a flange but the same idea can be used with a flange adaptor. The collector slips over the primary tubes and has a straight tube outlet. I use a strap clamp to attach another tube onto the collector then use 2 elbows to direct the exhaust out towards the rockers where the mufflers are. The mufflers now have turnouts on the outlets so the exhaust doesn't blow back onto the tires.
i know your car is a dedicated strip car. mine will be recreationally street driven and driven to the track, would i have any heat issues with the floor pan?
Car: 87 IROC L98
In your first post, you said it was a drag car and nothing about being street driven.
I have no issues with floor pan heat but I also don't have long run times to worry about it. If you were going to drive for an hour or 2 then it may get a little warm.
If you're that concerned about it, put a heat shield above the muffler. The factory uses a heat shield above the catalytic converter but it also gets a lot hotter than a muffler ever will.
You can also take it into an exhaust shop. They can easily fab up a system that will work.
i didnt think there would be a heat issue especially since as you stated cats get alot hotter than mufflers/resonators.
i will get that done after i get the 357 in the car. i got a buddy who would fab something up.
what did you use for hangers?
Car: 87 IROC L98
Similar to a factory style like this
I welded 3/8" rod to the pipe and to the underside of the car pointing in the opposite directions then slid the hanger on. Since those pictures were taken, I've also installed a hanger at the front to keep it from rotating down.
You can just barely see it behind the muffler
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
