Smoke from Pass side rocker cover
Old May 22, 2009 | 09:23 AM
andy625's Avatar
Car: Firebird 1987
Engine: 5.0
Dunno if anyone can give me any pointers on this but I've noticed that after a fast run, when I come to a stop there is a intermittent puff of smoke from the passenger side rocker cover area in the region of the breather.
I think the rocker cover gasket may be leaking as with the engine hot and running, when you stand and watch its almost something is dripping onto the exhaust every 4-5 seconds as there is a puff of smoke, then its ok for a few secs.
At first I thought the crankcase was getting pressurised by blow-by from the rings, but when I take the filler cap off the drivers side, there is absolutely no pressure or chuffing.
The breather in the pass side (that goes to the air filter) isn't blocked and was completely clear when I took it off, it was a very loose fit in the rocker cover grommet though.
The car is a 87 5.0 with carb and no pcv (that I know of). Has anyone else experienced this?
Old Jun 2, 2009 | 07:15 AM
andy625's Avatar
Car: Firebird 1987
Engine: 5.0
Re: Smoke from Pass side rocker cover
Well, smoking seems to have stopped for now anyway. Obviously I'm the only one that gets this.....
Old Jun 16, 2009 | 04:57 AM
andy625's Avatar
Car: Firebird 1987
Engine: 5.0
I seem to be the only one rading this thread, but just in case anyone else has these symptoms, see the end of this thread:
https://www.thirdgen.org/forums/tech...ml#post4191493
Red iroc-z 305
Sep 30, 2015 05:22 PM
1985chevydude
Aug 20, 2015 12:29 AM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 5, 2015 11:57 PM
