Help on engine "suffix" code.
Old May 22, 2009 | 07:10 PM
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
I got a 350 engine block casting numbers 14093638. Now its supposily from a 89 Iroc, But Idk the casting numbers just tell me 87-94. (could be truck car etc) but i herd the "suffix" code will tell him exacly what its from and exacly what year. Can some help me to where it is at? or how i can tell what this engine is from? Thanks
Old May 22, 2009 | 07:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Help on engine "suffix" code.
There should be a bunch of numbers stamped on a pad in front of the passenger side head. They're usually hard to read because of dirt, paint etc. Get all those numbers.
Old May 22, 2009 | 07:19 PM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
You can cross reference the numbers on the pass front of the engine block at nastyz28.com
Old May 22, 2009 | 07:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Nasty28 doesn't have a lot of the newer suffix codes since he deals mostly with second gens. It may be there but probably isn't.
Old May 22, 2009 | 07:33 PM
Curtisyz54's Avatar
V0303SNA in the number on the pad. I thought the s was a 5 and it confused the hell out of me, and I thought the engine was a 89, so i was looking for a z because 89 suffix starts with a z, But its SNA, And It say its a 1987 350 TPI. So I guess its from a 87 Iroc 350 car.
Old May 22, 2009 | 07:46 PM
Car: 87 iroc
225 horse with a little over 300 ft lb torque i know cause ive got one
Old May 22, 2009 | 07:48 PM
Curtisyz54's Avatar
well it will be like double the HP when Im done with it, Its going in my 84 z.
Old May 22, 2009 | 11:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
SNA 1987 350 225hp TPI L98, a/t
That's what my car had under the hood 10 years ago The engine is in a 66 Chev pickup now that belongs to the guy I bought the car from.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
