Torque on main caps and what fluid to use on threads?
Old May 25, 2009 | 03:25 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Did my search. I am kinda surprised that I could not find the answer to the above when I searched for "MAIN CAPS TORQUE".
So, what torque to use, its a 4 bolt mains,,, and what fluid should I use on the threads? red loctite (high strength), blue (medium strength), oil, nothing.
Old May 25, 2009 | 03:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Torque on main caps and what fluid to use on threads?
oil or ARP moly lube or some type of lube on the threads. NOT LOCTITE !
65ft lbs. 60 on the shorter ones IIRC. The amount of error in your torque wrench makes more of a difference then the 5ftlbs anyway so...
Old May 25, 2009 | 04:26 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Thank you for the reply. I have several engine build books, however, since my relocation to Florida, these books are missing in action. I got to find these books soon.
Old May 26, 2009 | 06:54 AM
morf33's Avatar
just a couple drops of oil dont soak them also i chase all the threads and blow them out
so that they are clean and dirt rust free, some chem baths and time open dirt and debree can get in as well as liquids chase blow out and lube the threads on the boolts will help also with the torqueing as well
xxx3man`
Sep 23, 2015 10:37 PM
Thornburg
Aug 25, 2015 01:46 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Aug 6, 2015 04:15 AM
