Need a smaller starter
Old May 27, 2009 | 07:39 PM
buickboat's Avatar
Car: 1992 Buick Roadmaster Sedan Limited
Engine: TBI 350
Transmission: Tremec T56
Axle/Gears: 3.73s with an Auburn posi
Putting true dual exhaust on my 1992 Roadmaster Sedan (TBI 350) L05 using LT1 exhaust manifolds and catayltic converters. One of the studs on the passengers side is hitting the starter solenoid.
Is there a smaller starter that I can use to fix this issue.
The only other thought I had was to take the starter off, install the cat and cut the extra length of the stud off and then reinstall the starter.
Old May 27, 2009 | 07:50 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Need a smaller starter
cut it off. i would say. but yes just look at jcwhitney or jegs.com they should have what you're looking for. a smaller high torque starter.
Old May 27, 2009 | 07:53 PM
AkitaMan's Avatar
Car: 1991 Flaming birdie
Engine: lo3-305 tbi
Axle/Gears: stock
alot of headers require a mini starter. Shouldnt be hard to find one.
Old May 27, 2009 | 07:54 PM
buickboat's Avatar
Engine: TBI 350
What number of teeth would my flexplate have? 153 or 168? I have been searching on it, but got myself confused. It is the stock flexplate for a L05 TBI 350
Thanks again.
Old May 27, 2009 | 09:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You're lucky. I use one of these and I need to pull my headers off to get the starter bolts out. One of the header tubes is dented to clear a starter bolt.
Old May 27, 2009 | 10:49 PM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
try a 4.3 starter or powermaster sells a clockable mini for 149.00
Old May 27, 2009 | 11:51 PM
EvilCartman's Avatar
Car: '82 Z28
Hitachi PSL100 starter, nice and small plus works great.
Old Jun 2, 2009 | 11:05 AM
buickboat's Avatar
Engine: TBI 350
So from the picture above I am assuming that a starter with inline bolt holes will work? This will be for a 1992 Chevy TBI 350 (L05). The original starter has bolt holes that are offset , but it looks like there is an extra hole that could be used in the case of a starter with inline bolts holes. If you guys could let me know ASAP that would be great so that I can order it from summit today.
Thanks!!!!
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
3rd gen money
Oct 11, 2019 09:57 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
bschmale66853
Sep 30, 2015 08:11 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
