Motor Castings
Car: 89' Camaro
Engine: 350 SBC
Transmission: Turbo 350
Motor Castings
Could someone help find some info on this motor
14010207 Block Casting
462624 Head Casting
Is the heads worth having ?
what year is the motor/heads
What was the stock HP?
What was it out of ?
Any help would be great thanks Guys/Girls
462624 Head Casting
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Motor Castings
Your block is an 80-85 350. Without suffix codes, there's no way to know exactly what it was from. Get the stamped numbers from a pad in front of the passenger side head.
The heads were common on 79-85 350 engines. They're large chamber smog heads and probably have the small 1.94/1.50 valves in them.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 87 IROC L98
Re: Motor Castings
V1107FSM
V = Flint engine plant
1107 = Nov 7
FSM = ??? I can't find that code anywhere. Are you sure that's what they are?
The letters are usually hard to read.
CE4115968 = The last part of the original vehicle's VIN
E = 1984
1107 = Nov 7
E = 1984
Re: Motor Castings
I have them exact heads, the 462624's. They have that odd "camel hump" design. Stephen, if you're still subscribed to this thread, do you know of any decent, complete heads that would be nearly a bolt on replacement? I was looking at Edelbrock, but I've never had any experience with them. Maybe it's just a default type picture, but their exhaust ports don't match.
I'm about 92% sure my heads are also cracked. I'm going to have to invest in new heads soon.
Car: 87 IROC L98
Re: Motor Castings
Just about any aftermarket head will do. A good junkyard head to grab is from a Vortec engine. I just sold a set from a 350 medium duty truck for $200 that were given to me
I had no use for SBC parts and $200 was a very good deal price.
I had no use for SBC parts and $200 was a very good deal price. Thread
