accessory help
Old Jun 5, 2009 | 06:58 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
accessory help
Ok its been a while since I took the top end of my lg4 apart. Im putting the accessories back on and apparently I didnt lable them good enough because I cant figure out the power steering and ac brackets. Does anyone have some pics or tips- its stock setup v belt, thanks guys
Old Jun 5, 2009 | 07:51 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: accessory help
Ok I got everything except the two bottom holes on the block- what is supposed to go there?
Old Jun 5, 2009 | 08:45 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: accessory help
nobody?
Old Jun 5, 2009 | 11:00 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: accessory help
howdy there
well on these '80's style usually nothing bolts to the engine block using these two holes.
the p/s pump brackets setup bolts to the water pump flat spot on the driver side one bolt hole hole threaded there in the pic,
top threaded stud in cylinder head by the water pump mounting bolts there
also using the first exhaust manifold first bolt stud that holds the adjuster slot bracket in place
and using the bracket between the lower a/c compressor and upper p/s pump setup
have fun
Old Jun 6, 2009 | 09:26 AM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: accessory help
Thanks I've been going crazy trying to figure out what went in those holes
BDR
Nov 7, 2015 03:05 PM
355tpipickup
Sep 28, 2015 05:50 PM
evilstuie
Sep 24, 2015 02:31 AM
Camaroguy2
Sep 22, 2015 08:22 AM
Mdenz3
Sep 17, 2015 08:36 AM
