Need help speedometer and conv.Top
How can I fix my speedometer?
and does anyone know where I can get a convertible top? Im close to Houston Texas
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need help speedometer and conv.Top
they hawks third gen for the top.
did you check and see if the plug in the tail shaft of the trans, driverside, was loose? it has a purple and a yellow wire. thats the speedo connector. Its most likely loose and causing the issue.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
We jacked it up and checked the tranny where we thought the cable would be connected only to find there wasn't one. I have done some research and now believe it to be electronic. I need any information that can help with fixing the problem.Drove it a few miles today and the speedometer would jump up and down then start working.
JamesC
Elephantismo
Feb 13, 2019 12:51 AM
