MSD location???
Old Jun 14, 2009 | 03:00 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
MSD location???
I finally gave in and bought an msd ignition box, only trouble is i have no idea where to mount it under my hood. Any pics of locations or any ideas are free here. Thanks
Old Jun 14, 2009 | 03:07 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: MSD location???
If you have an A/C delete box i "think" it'll fit right above it, just to the drivers side of the fan motor.
EDIT: meant to say drivers lol
Old Jun 14, 2009 | 07:45 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: MSD location???
lol nh i got no a/c setup but i dont have the a/c bx i got the original box jus filled the whole tht the lil tank and the lines took up
Old Jun 14, 2009 | 09:01 PM
ssean92's Avatar
Car: sold
Re: MSD location???
I put mine behind the engine on the firewall
Old Jun 14, 2009 | 11:30 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: MSD location???
I installed mine under the passenger seat and ran the wiring harness that I made for it under the carpet. I prefer to keep mine out of the weather and out of the heat....
Old Jun 14, 2009 | 11:35 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: MSD location???
I mounted mine on the driver side behind the vapor canistor, against the fender, tight fit, if I move it, I might put it under the center console if it would fit.
Old Jun 15, 2009 | 07:48 AM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: MSD location???
Pretty nice locations, doesnt it need air and to stay cool? The way my buddy ran it on his stang was rite in front near his hood release where you can see from the front and looks pretty cool
Old Jun 15, 2009 | 08:44 AM
skinny z's Avatar
Re: MSD location???
Mine is up front over the vapour canister. I bent up a piece of sheet aluminum for a base.
So far no overheating issues.
Attached Thumbnails MSD location???-img_4255.jpg   MSD location???-img_4253.jpg
Old Jun 15, 2009 | 05:35 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: MSD location???
Not bad I like that setup. Does it have to be a certain distance from the coil and dizzy?
Old Jun 15, 2009 | 08:36 PM
skinny z's Avatar
Re: MSD location???
Just within length of the premade harness.
Old Jun 16, 2009 | 08:41 AM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Re: MSD location???
Okie doke, i think all the info. Thanks everyone
Old Jun 16, 2009 | 09:31 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: MSD location???
I put mine where the fuel maf relay were,
Old Jun 16, 2009 | 03:36 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Re: MSD location???
I've removed my AC compressor and all that goodness on the firewall, welded it shut and put it on that wall.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
tonys91rs
Sep 2, 2015 07:07 PM
