charcoal canister
Old Jun 16, 2009 | 01:17 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
charcoal canister
since my car is brainless, and doesnt have any emmisions items other than the charcoal canister it seems to me that i could just as well toss it also?
if i understand it right it merely collects fuel vapors, yet the tank is also vented via a hose at the tank...... so other than the legality issues of not having it, any other problems?
edit, i figure i should add that the car was a carbed 2.8 originally and has been swaped to simple v8 with carb and hei dizzy
Old Jun 16, 2009 | 01:35 AM
*18436572*'s Avatar
Car: 83 z28
Engine: vortec5.7/predator/msd/lunati/teamg
Transmission: th350/transbrk/rev-manual v body
Axle/Gears: Ford 9 inch 4:56
Re: charcoal canister
yes you got it! it collects fuel vapors then reburns them for emission purposes,I have been upset by people disrespecting the charcoal canister by discounting it as another piece of emission junk and removing and throwing in the garbage!!!!! WTF!!!! the garbage is no place for the canister! It can be easily converted into shotgun target, rifle target,or pistol target!! come on people!!!!!!
Old Jun 16, 2009 | 10:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Just extend the fuel line going to it down through the driver fenderwell and out below the car - that way if fuel leaks out there for whatever reason it won't be under the hood catching fire from a header or stray spark.
Old Jun 17, 2009 | 12:40 AM
Car: 1984 Firebird
Axle/Gears: 4.10
or i could just remove that particular line altogether right? and cap it at the tank? seeing as its vented at the tank
Old Jun 17, 2009 | 01:27 AM
*18436572*'s Avatar
Car: 83 z28
do you have 1 vent that comes out of the pump module with fuel lines and the other one vents to the filler neck?
Old Jun 17, 2009 | 01:35 AM
Car: 1984 Firebird
Axle/Gears: 4.10
im gonna have to take a look, i think i follow you, if it helps this was originally a carbed 2.8 v6 car, so the only pressure built in the tank is from temperature change and sloshing
Old Jun 17, 2009 | 01:40 AM
*18436572*'s Avatar
Car: 83 z28
I would not just the fuel tank out to fender well of car,fuel will leak when fuel is sloshed around it creates pressure especialy when the tank is full,also consider fuel leakage during an accident,or on a steep incline dumping fuel anywhere is not good,most new filler necks incorperate a ball/check valve that will not let fuel come out when the car is upside down,I would just leave it connected to the caniser if you don't have any weight or space consideration's
Old Jun 17, 2009 | 02:05 AM
Car: 1984 Firebird
Axle/Gears: 4.10
really no reason other than while the motor is out i want to get rid of stuff i dont need, just tired of looking at the clutter of useless stuff tho thats about all that remains aside from some wires that go to the computer(which will also be leaving) and figure if the old mans 74 nova doesnt have it it must not be too important
im not worried about weight, nor space really only thing i may wish to put there is an ignition box, but i doubt the harness will be long enough its more likely going to live above the ac delete box if there is room
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
TBRays98
Sep 6, 2015 05:05 PM
