thinking about building an engine
Old Jun 17, 2009 | 06:01 PM
kowalzekc's Avatar
I am thinking about building a small block for my 92 formula and I had a few combinations in mine, but first I have a few questions. First off, what is the max a 350 can be punched out to safely? Second I am debating if a supersharger is going to be an addition so what is reccomended for compression with a super charger? Also, who makes decent lightweight internals??
Old Jun 17, 2009 | 07:01 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: thinking about building an engine
I wouldnt bore a 350 anymore than 60 over unless you want major problems. Superchargers dont need globs of compression so with a 350 don't run flat-tops pistons and try to stay below 9.0to1 compression.
On the same note, machining any motor for larger pistions raises compression.
Old Jun 17, 2009 | 07:15 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
engines should be bored only enough to clean up the cylinder walls, you would feel no difference in peformance between a 4.000 inch bore and a 4.060 bore.
Old Jun 18, 2009 | 05:38 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
If you are absolutely sure that you are going with a supercharger, then build it with 8.5:1 compression ratio. If you have a used 350 block, just go 30 over (4.030" bore). This will force you to buy new pistons. And while you are at it, you best buy a forged crank due to the supercharger, so you might as well build a 383. There are plenty of good engine parts for a 383 build and several manufacturers of these parts.
BTW: not all 350 blocks can be bored out to 60 over; most maybe but not all. That is why two of us are recommending 30 over.
When I built my 395 cu.in. stroker, I did alot of research on the matter. Do alot of searches and bookmark the engine component sites that you find. Also, buy a couple engine build-up books. The most important component that you are going to buy is the crankshaft. I went with the forged Callies Dragon Slayer. I think that its the best forged crank for the money. Well, thats my 2 cents worth.
Old Jun 18, 2009 | 06:01 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Doc, not at all recomending a .060 overbore....just if it has to go to that much of an extreme anything over .060 might as well be thrown away.
I agree that .030 over is not only reletively standard but safe and would never recommend a motor be cut anymore unless it absolutely had to be.
Old Jun 18, 2009 | 06:43 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Jay: Please dont take me wrong here. I was not coming out here for a fight. I guess we do agree that 30 over is common place and well recommended for a "safe" over bore amount.
Old Jun 18, 2009 | 08:06 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I had a .060 over motor that lasted for about 3k miles in a buddy's ride, I got it and it and rehoned it and as soon as I drove ita round the block, one of the bores cracked.
If you can get away with it, punch .010 over. There's no need to use up a block that way. The more meat you leave in the bores the more rebuilds that block can take.
And this was a nice 4-bolt block from a 72 Chevelle I think. Probably superstitiously regarded as a "desirable" casting. Didnt do much for me except cost me a bunch of money.
Old Jun 18, 2009 | 11:02 PM
kowalzekc's Avatar
Hey thanks gents. I appreciate all the info. WHat are some good books to read?
Old Jun 19, 2009 | 04:46 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Chevy High performance Engine Assembly Guide by Alex Walordy.
and
How to rebuild Your Small-Block Chevy by David Vizard (HPBOOKS)
midge54
Jan 29, 2017 07:00 PM
italiano67
Dec 11, 2016 09:21 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
