Power loss when pressing gas
Old Jun 21, 2009 | 06:32 PM
Anubis6428's Avatar
Car: '88 Iroc-Z
It started out when I start my car in the morning if I press the gas peddle to rev the engine the rpm's go down instead of up and its like all the engine power cuts out. After it warms up its will usually stop doin this until recently. I was on the highway this weekend and when I tried to gun it and pick up some speed it seemed like the engine shut down completly, but when I took my foot off the gas it cut back on and started working normal. I did it a few more times and it did the same thing every time,
anyone know what could be causing this?
Old Jun 22, 2009 | 12:17 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Power loss when pressing gas
had something close to this. fuel pump is what it ended up being.
check fuel pressure like i did and drive it and see what the pressure is when it does that.
Old Jun 22, 2009 | 07:20 AM
Anubis6428's Avatar
Car: '88 Iroc-Z
I would do that but my fuel pressure gauge isnt working now. I took off the Air Intake Temp. Sensor to clean it, and it seemed like after that it just stay maxed out now. So I dont know what to do about that?
Old Jun 23, 2009 | 12:15 PM
halostryker's Avatar
Car: 84 Camaro z28
Engine: 305. LE9
Transmission: 700-R4
Axle/Gears: 3.42:1 Locking
I had that exact problem except after it warmed up it was fine. but any ways a just had my carb rebuilt and its worked fine after that. i know it will be expensive but its the price we pay to have a nice camaro/transam lol
Old Jun 23, 2009 | 06:37 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
It you're willing to take your time with it, a rebuild is pretty cheap to do yourself.
Old Jun 27, 2009 | 11:24 AM
Anubis6428's Avatar
Car: '88 Iroc-Z
Yea, I would do that but my car is Tuned Port Injected, I dont have a carb. When My carb shot out in my 69 chevy truck I rebuilt it in about 4 hours had it running again, simple enough. Wish this one was carbed though, Thanks anyways.
Old Jun 27, 2009 | 11:47 AM
Guest
Guest
Posts: n/a
Check your throttle position sensor voltage. Closed throttle, wide open, and everywhere inbetween engine off key on. Should be ~0.5V to 4.5V closed to open and transition smoothly as you open the throttle.
Old Jun 27, 2009 | 12:06 PM
spimonkey34's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Transmission: 5 Speed
I don't know if the '88 305 is MAF or not. If it is, check for any leaks after the MAF. Could be a problem with the MAF as well.
Old Jun 28, 2009 | 11:56 PM
erc07's Avatar
Car: 87' IROC-Z
Transmission: Automatic
yeah, im having this exact same problem. and im stumped. but i am a n00b... lol
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Sep 17, 2020 08:26 AM
355tpipickup
Aug 13, 2015 07:35 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
