Smell of Gas... From Tank
Old Jun 24, 2009 | 12:24 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I had something happen to me yesterday that I thought I would pick your brains about...
I drove my car and it was a pretty hot day, around 85°F and on my way home it became rather warm Temp reading, not a big deal as it did not go above 215°. As I was Backing the car into my Garage, I noticed that there was a whiff of Gasoline Smell. I got out and smelled under the hood, nothing there. But it was more noticeable toward the rear of the car.
I did not have time to investigate at that moment, so I let it be and about 5 hours later I went back into the Garage to see if there was something I could smell... The smell was gone, but I remembered that sometimes a loose gas cap could cause this. So I checked the Gas cap and when I loosened the cap I hear a big Sucking noise... and a small "pop" from the gas tank either expanding or contracting.
I do not think the tank had extra pressure as it would have given me a gas smell, which I do not remember getting when I loosened the Cap.
My first thought is the little filter that is attached above the axle, as I suspect this allows air into the tank, and then extra pressure is released through the Charcoal canister.
Any thoughts, and/or anyone else experience this?
JOhn
Old Jun 24, 2009 | 12:37 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: Smell of Gas... From Tank
First thought: I'm not crazy! lol
This happens to my car too. At first I thought it was the gas tank recall issue, took it in and had the tank pressure tested, and nothing was wrong. Every time my car's gas tank is over 3/4 full this happens, but no one can find that there's actually a problem.
Old Jun 25, 2009 | 07:48 AM
okfoz's Avatar
My car has about a 1/4 tank... so it might be related, but how...
John
Old Jun 25, 2009 | 08:07 AM
GeneL's Avatar
Car: 1983 Camaro Sport Coupe, T-Top
Engine: LG4 5-Liter V8, 305cid
Transmission: NWC-T5 Manual 5-speed
Axle/Gears: GU5 Axle Ratio 3.23 Rear
About this time last year I was noticing the smell of gasoline, especially when seated inside the car and couldn't figure out where it was coming from so I took it to my mechanic and just when we popped the hood we both noticed drops of a fluid coming from the left (passenger) side of the engine area. Did the dip finger and smell test and sure enough it was fuel.
It happened that one of the two rubber (? or whatever they're made of) fuel lines on the left side of the engine had a small split in it and was leaking.
He replaced all the fuel hoses up front (couple of feet worth), new clamps and for $105 this took care of the problem. He also suggested I replace the ones in the rear coming from the fuel tank but, because this involved actually dropping the fuel tank itself (big bucks) I passed on that one for the time being.
The fuel lines he replaced were at least 25 years old (I know being the original owner) and considering he took care of me right away without leaving the car even though he had a few customers waiting I felt like the 100 bucks and the quick service to take care of a potential fire hazard was money well spent.
Check those fuel lines, look for anything leaking, wet your finger and do the smell test to see if it's in fact gasoline. Of course, since it's gasoline, you could have a leak you don't realize is there because fuel evaporates so quickly so, you could rub your fingers around the hoses themselves to see if you pick up anything "wet".
Good luck!
Gene
Old Jun 25, 2009 | 08:12 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Change your gas cap w/ a new one...
Old Jun 25, 2009 | 08:08 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Same problem. Only happens in hot weather. Hissing noise coming out of gas cap. Charcoal canister replaced, tank vent valve replaced, purge solenoid replaced and fuel lines are all good. Changed tanks and fuel pumps. Nothing yet???
Old Jun 25, 2009 | 08:26 PM
J91's Avatar
J91
Had the same problem, replaced the gas cap, no more problem!!!!!
Old Jun 25, 2009 | 08:28 PM
campin1983's Avatar
See I'd agree with the gas cap theory, except my fuel tank/system has been tested by the mechanic. No leaks, no bad gas cap, no need to replace the tank (recall check), nothing. I quizzed them about it, cuz i was certain, and they said there was absolutly no fuel system leak.
Old Jun 25, 2009 | 08:31 PM
J91's Avatar
J91
$7.00 fix, did it last week, no mechanic necessary...LOL
loud91rs
Oct 5, 2015 10:05 PM
Dwayne614
Sep 29, 2015 11:05 PM
dusterbd
Sep 29, 2015 08:40 AM
lanceflame44
Sep 25, 2015 12:28 PM
Glowsock
Sep 11, 2015 11:09 PM
